Canon IR 1023n adding a fax
  • Gregg
    • Aug 2025
    I have a 1023n I want to add fax to. I have a 1023if that was dropped, Can I use the fax out of the IF in the N machine and just change the necessary parts?
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Does not look promising...
    There is no fax option in the service guide, and only the iF model has fax in it. I do not know if the parts can simply be moved from the N to the iF model. You are free to try anything you want, but I don't know what your results will be.
    • Gregg
      well i swapped the parts and it was relatively easy, All the buttons work, the fax button lights up but no dial tone, it never dials. Firmware maybe?
      • mrfixit51
        • Oct 2008
        • 1975
        There is no different system software for the 3 models, they all use the same version... it would not hurt to try, maybe in the loading it would "discover" the fax parts, like I mentioned earlier, I have no way to predict the outcome here, you are the one pioneering this!
        • teckat
          • 16083
          did u put in those two fax cables
          DDR MODULE PCB ASS'Y are diferent on image processor
          FM2-4055-000
          iR1023N/1023/1022N/
          iR1022F/1022A/1022/
          iR1018
          FM2-4056-000
          iR1023iF/1022iF/1022i
          • Gregg
            Yep I made sure everything is plugged in and it visually looks Identical to a IF model.
            weird, Im going to check it out further, I'll let you know if I find something out.
            Thanks Guys
            • teckat
              • 16083
              u did swap those DDR MODULE'S ?
              • Gregg
                I did not, I'll try that.
                • mrfixit51
                  • Oct 2008
                  • 1975
                  If the DDR swap does not resolve it, try reflashing the copier with the latest software. Keep us posted...
