ImageRunner C5180 ITB Gear Part Number
  • listsubscriber
    • Aug 2008
    • 83
    Anyone know the part number for the gear on the ITB that is driven by metal gears on the back side of the machine? The plastic gear on the ITB has worn down and skips causing paper jams and loads of toner being dumped onto the transfer belt.
    Thanks in advance
  • Gamut
    • Jul 2008
    • 216
    Assuming this is the 1 with a pin in it, FU7-0406-000
    • listsubscriber
      • Aug 2008
      • 83
      I think that is the one! How in the heck did I miss #22 on my diagram?? Thanks a bunch for the accurate, quick reply.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        I am getting set to replace one on a 4580 as well,, color registration issues. The number was indeed accurate!
        • teckat
          • 16083
          i would also check & inspect the
          Swing Gear Assembly
          FG6-9662-000
          • mrfixit51
            • Oct 2008
            • 1975
            Swing Gear Assembly
            FG6-9662-000
            [ATTACH=CONFIG]4678[/ATTACH]
            FM3-3775-000 is the correct part number for the swing gear assembly for the iRC5185, which should be accompanied by FU7-0407-000 the gear that is on the drive shaft.
            • teckat
              • 16083
              sorry , your right/ was thinking of 3220
              • larrybrown
                I need this gear as well for a grinding noise and ITB not moving. Anybody have this gear in stock?
                • teckat
                  • 16083
                  3220 or 5180 ?
                  what gear ?? swing guide gears or ITB end Gear
                  • larrybrown
                    Sorry about that. The C5180 gear part number FU7-0406.
                    Thanks.
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      Thanks.
                      No, I am still awaiting mine, it has been expedited for delivery, I was supposed to have it today, but the fates ruled against me...
