Canon MP550 - 6C10 Error Message
  • TonerMunkeh
    Professional Moron
    • 3865
    Ayup,
    Got one of these MFP jobs with the error code 6C10 - any ideas anyone? Pretty please?
    Hit it.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    absorber full error message is the only thing I could glean from a Google search...
    • TonerMunkeh
      Professional Moron
      • 3865
      Yeah, I saw that too. I managed to get into service mode, however it only sits there saying "Service Mode, Idle". Is there any special jiggering that needs to be done to access other functions in service mode, i.e. PM counter reset? Does service mode mean using a PC tool to connect to the printer?
      Hit it.
      • mrfixit51
        • Oct 2008
        • 1975
        I know nothing of the inkjet printers, I spend all my time working on the larger toys. I assume that there is a way to zero out the absorber pad counter, I just have no idea how to...
        • TonerMunkeh
          Professional Moron
          • 3865
          Thanks for your help anyway dude.
          Hit it.
          • teckat
            • 16081
            MAY WORK ON A MP550
            Here this step by step to resetting waste ink counter printer Canon Pixma MP450
            1.
            You will turn off printer.
            2.
            retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
            3.
            you will let go button Resume/Cancel, continuing to retain POWER.
            4.
            press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
            5.
            when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
            6.
            you will turn off printer by button POWER.
            *** Some models have a Stop/Reset button instead of Resume/Cancel button.
            • yopeace92
              You've probably solved the problem by now
              but i removed my ink cartridges and the bottom cassette of paper,
              when i turned on the printer it registered there was no ink so after replacing the ink i could then finally access the home screen and clean the paper tray roller.
              It seems to have worked, so hope this is some help
