imagepass-c-1-driver
+ More Options
Posts
  • Ikon Princess
    • 126
    http://www.copytechnet.com/forums/co...-1-driver.html
    OK I will try here.
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Sorry, I can't find any PS x64 drivers either. They don't like the PCL driver? I suppose you could try the ColorPass PS x64 driver, but I don't know if it will even work.
    • Ikon Princess
      • 126
      PCL doesn't play nice with their applications. But at least now I have another direction to look in.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Hi,
        D_L_P is definitely on the right track.
        Try the ColorPASS GX-100 PS drivers for your OS.
        They seem to work when there isn't a "current" driver available.
        I can't say I've tried it on a C1 RIP, but it's worth a shot.
        Good luck!
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Originally posted by KenB
          Hi,
          Good luck!
          A highly recommended option.
          • Ikon Princess
            • 126
            Thanks screwtape and others I will try the suggestions as soon as the customer returns to his office on June 1.
            • ricardobres
              • 147
              Taking advantage of the subject, there're a driver for windows seven?
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Actually. the GX-100 driver only lists Vista, which should work, but the GX-200, which will work as well as the 100, can be found at: Canon U.S.A: Support . It specifically lists Windows 7.
                Good catch! Thanks!!
                • Dalamar
                  • Oct 2006
                  • 117
                  Ikon Princess, please forgive me, but there is something that most are thinking but are probably too afraid to say (see below).... The reason for this is based upon Rule 30, 31, and 32 of the internet. I could go a bit farther and cite rules 27-32. If you are unfamiliar with the Rules of the Internet I will post them also.
                  Notatechie - "I am trying, but I don't know how to go into Service Mode. If I just go in and press *then 2, than 8, then * it does not do anything."
                  SCREWTAPE - "Try harder.."
                  • teckat
                    • 16083
                    [ATTACH=CONFIG]4731[/ATTACH][ATTACH=CONFIG]4732[/ATTACH]
                    THAT was
                    a
