unreadable printing
  • CHARLESCWS
    • Jun 2025
    [Misc] unreadable printing
    I have a Canon IRC4580, when I print, my image is not clear. It is like when you try to read the printout it
    pains the eye? can anyone help please?
  • teckat
    • 16083
    are u a tech. or end user ??
    u have to check the obvious first> u need to print out a PG6 GRID Pattern to determine if issue is in paper feed or cross-feed.
    if u are a tech.
    and issue is cross-feed,u can clear Reg.Data in Level 2-Enter Service Mode: Level 2 > Copier > Function > Clear > Reg/Clear. Highlight Reg/Clear and press OK.
    After performing the clear, reboot the machine and perform a Gradation Quick Adjust and then a Full Gradation adjust
    u can do a DCon clr if that does not work/ but u have to print out a P PRINT Report to input the settings back.
    As an ITB is used, over an extended period of time, it may become loose causing a small buckle to occur. This buckle may cause the image on the ITB to become blurred or smeared.
    Also the ITB belt interior drive rollers become slick/backside of belt becomes dirty/causes it to slip and drift= blurry copies/prints.
    Belt Needs to be replaced if old/ or interior rollers cleaned
    u could also have a Drum/Laser issue/ or need to do a Pattern Reader
    adj.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Check out my tread http://www.copytechnet.com/forums/ca...n+canon+models. There is some info regarding certain procedures to be taken for issues like yours. Look for registration issues.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        You have been asked questions and not replied. If you hope to receive assistance with your problem, communication is the key!
        My question for you is this: are the colors not lining up, so you have a misaligned/rainbow effect on color prints, and are black and white prints o.k.?
        • teckat
          • 16083
          CHARLESCWS
          is MIA
