Canon IR2016 developer replacement
  • jonbonse
    • Jun 2009
    • 737
    Hi
    I just ordered a dev assy for an IR2016 but it came with no dev in it.
    I'm guessing these copiers don't have the dev seperate from the toner?
    Please let me know if I am right. . . .
    Many thanks
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Did you order the correct part. It should come in tact with the dev ass'y
    P#FM3-3671-000
    • jonbonse
      • Jun 2009
      • 737
      Thanks for the reply!
      It is he part number you mentioned above. ..
      I am told that Canon monochrome copiers are mono component (just the toner which has dev already mixed in with it).
      So hopefully after installing the dev assy, running the developer idling mode operation, then installing the toner bottle, it will be ok. . . .
      • Canuck
        Tech Specialist
        • 1713
        Its mono component...no dev(carrier). Shake the toner cartridge and stick it in the machine
        • SCREWTAPE
          East Coast Imaging
          • 3396
          You've been told correct. The machine sometimes does it on it own.
            • 16083
            Best Bet= get a Manual/ read up on the printers u need to service
