LaserBase MF 3220
  • DadO
    • Dec 2007
    • 404
    LaserBase MF 3220
    When i press start key, scanner move, it finish the scanning but copier isn't printing anything after powering on, it just stay like that. I can only cancel the document and start all over again whit same results. I can't put machine in stand-by mode too. After I replug the power connector, machine start to work normal!? Whit all function even stand-by mode. If i wait till next morning same thing happen ( lol).
    I cleaned the power and DC board.
    No error codes present at any moment.
    I have no clue what to do.
    Please Assist whit Any suggestion.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Don't know much about this unit but check the fusing component.
    I've had small devices pose similar symptoms and turned out to be fusing.
    • DadO
      • Dec 2007
      • 404
      Thanks Screwtape. I will check it.
      • 1copy1
        I have a problem. Copy, but still. I will choose 5 copies. Makes 8 - 15, and paper jams. The pick-up clutch and sensors is OK. Fixing assembly looks OK. Board reset .. Please anyone an idea solution? Thx. 1c
