canon cp660 Error code E216
  • remielee
    Technical Analyst
    • Mar 2010
    • 140
    hello sir did you already incountered this error code in canon cp660 E216 it said in the manual
    E216/E219
    Cause
    -Fluorescent
    lamp
    -Inverter PCB
    -Reader controller
    PCB
    i try to change those parts but still the error appear, i clean the flurescent sensor board and chnge it its the same the lamp is have a light when it copies. what do u think guys about the said error? wait for your reply sir, thank you very much. and godbless......
  • D_L_P
    Self Employed
    • Oct 2009
    • 1195
    I've never worked on one of those, but CCD units have been known to cause lamp codes even though Canon doesn't list it as a possible cause in the book.
    • remielee
      Technical Analyst
      • Mar 2010
      • 140
      Sir D_L_P thanks again for the response, ic i will try it also to changed it. I'll post a reply and let you knw what will happend, once again thank you very much!
      • D_L_P
        Self Employed
        • Oct 2009
        • 1195
        Another thing to check is the scanner frame. Those have the free standing scanner and if someone leans on the front and the frame gets warped it will cause lines or weird error codes.
