Canon IRC2880
  • copy_suhail
    • 88
    Canon IRC2880
    Good day to all
    Can you help me if there any solution to resolve the 00045 error in Canon IRC2880 without replacing the OHP sensor
    thanks......
  • costd
    • Jan 2008
    • 409
    If you mean E045 - it is the error associated with the OHP sensor. Could be that the right door is not fully closed at the bottom and light is getting in. The sensor may be out of position, or it may be bad. If you checked the above - get out your service manual and look up how to test the sensor status/state. If you are not a Canon tech and/or do not have a service manual, you should call a tech. The sensor is IR and cannot be seen just looking at it (although I have heard of some trick using a camera).
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Make sure its seated well.
      If you look at the photo of the sensor it looks seated but its not seated well.
      Part #(RH7-7129-020)
      • teckat
        • 16083
        that sensor is a pain in the 18834-mean-agress&#1.jpgto Replace/ get a bottle of Aspirin
        • SCREWTAPE
          East Coast Imaging
          • 3396
          I know!!!
