IRC2880
  • copy_suhail
    • 88
    IRC2880
    I replaced a new magenta toner and the copier still tell to replace it
    any help pls.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Have you tried another magenta toner bottle.
    What is the firmware on this machine?
    • teckat
      • 16083
      any help pls.
      Clean the toner sensor in the Magenta Hopper assembly
      #22 circle in RED
      - CLICK ON PIC
      just to add on/ if u ever receive the message “Insert drum cartridge” & it is falsely
      displayed despite the presence of the drum.It occurs when the ITB unit has
      reached close to the end of its expanded life and the resistance of the primary transfer
      roller has been increased after some period of time.
      During the life of the ITB Unit, resistance against parts around the Primary Transfer
      Roller causes a decrease in the primary current at the drum detection sequence. This
      symptom may occur more frequently in a low temperature, low humidity
      environment.
      Canon has recommended performing the following
      procedure:
      Procedure:
      a. Clean the Transfer H.V. PCB (HV2) Contacts.
      b. Clean the Process Unit contacts to the main frame.
      c. Upgrade the DCON to v61.01.
      contacts shown with Red Line below / click on pic>
