Stack Bypass Problem - IR3300i
  • dbmoylan@gmail.com
    • May 2010
    • 89
    Can anyone please advise what part & where it might be obtained (or possibly procedure) to fix a stack bypass paper recognition problem.
    My IR3300i will not recognize the letter size paper being fed into the stack bypass - and an image of the bypass comes on the display saying wrong size paper inserted.
    Unit ran fine using stack bypass but now having this problem. Had problem a few years back & tech put used part in side that worked for a couple of years until now. Thanks.
  • dhanesh
    • Jun 2010
    • 63
    hey dismantle the bye pass tray and clean that sensor inside tray then make sensor belt in right alignment position for letter size
    DHANESH
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      COPIER>FUNCTION>CST is the key
      • teckat
        • 16083
        TO add on mrfixit51 procedures
        Product : imageRUNNER 2200 / 2800 / 3300 / 3300i Title : The Multifeeder does not Recognize the Correct Paper Size.
        It may be necessary to enter the values for the Multifeeder in Service Mode > Adjust > CST.Perform the adjustment of the Paper Width Basic Value in Service Mode > Function CST.Next check the Multifeeder Tray Timing Belt position, it may need to be adjusted.
        Note: Follow the steps below to adjust the Timing Belt position.
          • May 2010
          • 89
          Thanks guys - I will do as suggested & advise.
          Just to clarify, when you say "multifeeder" you mean the side stack bypass tray (not the Auto Doc. Feeder). I am having some type of problem w/ the side stack bypass tray (aka side manual tray).
          I will execute above procedures to troubleshoot the side stack bypass tray.
          Thank you.
          • teckat
            • 16083
            Thank you.
            in this model the Stack Bypass is called a MULTI FEEDER
            click on pic below>
              • May 2010
              • 89
              OK, did the auto. adj. function & still coming up w/ telling me to adjust paper width. Can someone please clarify, what size is the 8 1/2" x 11" paper when fed long side into the multi-feeder? Is that the MF-A4R size?
              I've also punched in the values per Mrfixit51 manually. Not recognizing the paper, and even goes off shading the orientation for the 8 1/2" x 11" paper fed long side into multi-feeder. Appreciate any suggestions.
              Thank you.
                • May 2010
                • 89
                Guys, was able to adjust with the following values - manually inputted:
                MF-A4R - 113
                MF-A6R - 223
                MF-A4 - 18
                Had to also do a slight calibration on the belt / sensor under the MF tray, but could not adjust properly until the values were manually inputted as identified above.
                THANK YOU ALL - could not get to service mode w/out your help.
                • teckat
                  • 16083
                  MF-A4R - 113
                  MF-A6R - 223
                  MF-A4 - 18
                  how u got those adjustments to work is a miracle
                  factory default after ram clear is MF-A4R-141 MF-A6R-235 MF-A4-26
                  do u have an old or orig.service setup spec sheet from copier ?
                    • May 2010
                    • 89
                    Went to the IR5000i w/ the info. you guys gave on accessing the settings & checked & used those values for the IR3300i. Was informed also that the part no. for the belt & sensors are the same in the IR3300 & IR5000 units.
                    THANK YOU GUYS!
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      THANK YOU GUYS!
                      You are welcome!
