SST
  • ione_ganesha
    • Oct 2009
    • 5
    SST
    PLEASE NEED HELP
    I NEED CANON SERVICE SUPPORT TOOLS (SST)VERSION 3.34 OR HIGHER SOME BODY CAN SEND TO ME OR ANY SITE I CAN DOWNLOAD IT.
    PLEASE.
    email : ione_ganesha@yahoo.com
  • teckat
    • 16083
    Originally posted by ione_ganesha
    PLEASE NEED HELP
    PLEASE.
    check this link below/ remember buyer beware
    Deposit Files
    Click on free downloading in below link SST v422Et
    http://depositfiles.com/en/files/me6aw24j6
    • ione_ganesha
      • Oct 2009
      • 5
      thanks friend it work
      • omarious55
        Re: SST
        thanks
        • kingpd@businessprints.net
          • 921
          Re: SST
          So what exactly all can you do with the Canon SST? Is it like the Xerox PWS where you need it to do machine diagnostics and setting adjustments in the machine other than the traditional *28 whatever method for Canon? Or is for transferring firmware? Does each version get new machine updates?
          • teckat
            • 16083
            Re: SST
            SST=SERVICE SUPPORT TOOL
            USED FOR>Flash Upgrade Function
            The current and future line of the Canon Digital B&W, Color imageRUNNER, imagePRESS, Color imagePRESS,
            and Color Laser Copiers will contain Flash Dual In-Line Memory Modules (FDIMM). Each of these modules
            (number, function, and location depends on the particular copier model) contain firmware providing machine specific functions and instructions. As such, each module can be updated in the field using the Service Support Tool as bug fixes and or new features are added to the copier. Upgrading the modules is known as Flashing.
            Additionally, certain models will have the functionality of being able to also have the BootROM, DCON and RCON flashed with this tool as well as downloading System, RUI, MEAPCONT, Key, SDICT, TTS, Browser, ASR, WebDAV, Media, Help and Language Files to a Hard Drive. Some models will also need this tool to perform HD formatting on new, blank, service part OEM Hard Drives.
            Backup/Restore Ram Data
            Each copier is adjusted at the factory, and its adjustment values are recorded on the service label. If replacing any PCBs with FDIMMs attached or initializing RAM, the corresponding values will be affected. Using the Service Support Tool a backup file can be created and saved on the PC. Once the PCB has been replaced, the RAM backup file can then be restored to the copier, and its factory setting restored. Various other user settings stored on these PCBs may also be backed up and restored when required. Note: It is unnecessary to backup\restore RAM data when upgrading Firmware.
            Obtaining Software Files
            Software files may be available by different means, such as e-Support or CD-ROM distribution(CD-ROM discontinued by Canon).
            From e-Support, files will be collected into a self-extracting data file. This data file will need to be expanded. The default location for this expansion is the C:\Canon File Folder\SST System Software Folder\SST Files.
