"this post was on a 5000 error issue/
u should re-post under a new topic under a 2830/e602-0001
602-0001 does not always mean HDD is toast- First Check the Ribbon and Power cable to the Hard Drive-
before replacing HDD u want to check if it is a HDD issue or a power supply issue
try this - remove cable from HDD/ power up n' see if it gets to main screen to pop the E602 code/ if it does not u could have a power supply problem/ if it gets to main screen with code u have a HDD issue"
Hard drive is definitely bad.... we haven't change hard drive on a Canon, therefore don't know much about it... where can I get the software and how do I load again on the new Hard drive, the old one is completely messed up...
Thanks for assistance
