Network settings iR105
  • Tommy
    What is the setting on the 105 to get it to talk to the network?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    You first should determine if there is a printer kit installed first. If so then follow the instructions below.
    You have to go into addition functions> system settings> network settings>TCP/IP and configure.
    Are you the IT network admin..
    • Alan Aya
      Screwtape is right, after you have configure the network setting and install the printer & scanner driver, you are now ready to print and scan with the iR105.
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Just to add to Screwtapes post, the easiest way to tell if you have network printing capabilities is to see if you can print a Printer report.
        Additional functions-> Report Settings-> Printer
        If on the right column you don't see Printer then you don't have that function. Press Printer to see what languages you have installed, you should see PCL and PS if you have that option. I think UFRII came out after the 105.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          If I remember correctly, UFRII came with the iR105+, which is actually a different model than the ir105.
