canon c3480 E742
  • jerome
    • Aug 2025
    [Error Code] canon c3480 E742
    hello
    I am a canon distributor from france
    I must to repair a c3480 but this model don t exist in france, yesterday I replace the hard disk because E602 code, I download the system and today the copier says E742 and E743, I think the system is don t the same that the french system but I m don t sure
    does anyone tell me any information for version in service mode?
    thank you very much
    jerome
  • teckat
    • 16083
    Originally posted by jerome
    hello
    thank you very much
    jerome
    E743 = DDI communication error
    0001 =The reader controller PCB detects communication error
    between the main controller PCB and the reader
    controller PCB.
    Disconnect and then connect the reader communication
    cable connector/while machine is off.
    Never heard of a E742 Code !!
    U need a crossover cable/connected from printer to laptop.
    When u replace a HDD on an imageRunner, you First need the Canon SST Tool loaded on a Laptop/then u need the iR3480 Firmware loaded in SST Program, then u need to use the HDD-Format file ver. for said model to format HDD first, before the machines Firmware is loaded on it.
    After u format HDD/ select ALL-HDF in models firmware screen
    Firmware for France is supported / latest is v92.05
    • jerome
      controller PCB.
      thank you very much for your reply
      I disconected the reader cable,
      I replace the controller pcb, the dc-con and the hard disk
      I download the V92.05 with SST with all hdf
      V92.05 is supported for the c3480? I thought that there was another version...?
      I don t understand the probleme, I have everything replaces, I think
      do you have a c3480 in your compagny? Could you say to me which version goes "engine kind" (factory mode) has l origin on one c3480 to compare with one c3580, the model we have here in France
      thank you very very very much for your help
      You are very nice help to me
      sorry for the quality of my english....
      best regards
      jerome
      • teckat
        • 16083
        best regards
        jerome
        why did u waste time replacing those expensive parts ??
        that is latest firmware for it
        u have a 3580/ u said u had a 3480 ??
        did u FORMAT that HDD first with the HD Format file v00.09 under the 3480 SST firmware window.
        Make sure u select iR3380_V3_v92.05
        in there u will see the HD Format file/ and the ALL_HDF
        if u did not Format HDD first in SST/ your machine will never work
        where did u buy that HDD Unit/ not all generic off the shelf hard drives are compatible with Canon imageRunners
        • jerome
          hello
          I have return c3480 into my workshop, into my workshop I have one c3580 (c3580 work correctly)
          I took cards and hard disk of 3580 and I them is put on 3480, for being sure, I prefer re-install the system v92.05 with the sst, all hdf, and I always have E743 code and E742 code
          I think there is anything is different between the 3480 model us and 3580 model europe
          It s why I would like to have the version of the engine kind of one c3480 of origin because it does not display on my 3480 which is out of order, I would have like compare it with that one c3580 because I think that a card is different between our models 2, can give me yourselves this information? is it possible?
          thank you very much for your help
          best regards
          jerome
          • teckat
            • 16083
            where did u receive this 3480 from/ it may have had electrical issues before.
            Did you print out a P-Print / Data Print for 3580 before you removed it's HDD/ what was the firmware ver on 3580 before u removed it ?
            You took out a working 3580 HDD, that had good firmware installed/ put it in a machine that had a E602 issue/ overwritten it's working firmware.
            do u now have two machines that do not function ??
            You should put back the Boards you removed from 3480/ put them back in
            next/put back the original HDD you removed from 3480/ do HD CHECK on it/ while hold down 1 & 9 key _turn on 3480 wait to see if it goes in download screen with white blocks dropping in sequence/ takes about 30min./ if it finishes ok/ re-load 3480 firmware with selecting the ALL / if u receive an error 602- do a format of HDD, then a ALL-HDF
            never heard of a E742
            like i said the E743 is from that READER CABLE/ u need to unplug 3480/ then remove & re attach cable/plug back in
            it may be time to get a Canon trained service tech to inspect your issues
            • jerome
              hello
              again think you for your replies
              I made always all it, I have one c3480 don t function and one c3580 this one function well
              7 time on 10 I have the E742 code
              when I say to CANON france he says me that the c3480 don t exist in europe market and he don t help me
              it s why, I seek the solution in the usa... it s the 3nd site that I try but impossible of find A technician who has one 3480 in stock or to one customers to give me the values engine kind, because if these values are not same the probleme never could be resolve it means that c3480 and c3580 aren t the same copiers, do you have a c3480? could you tell me if the value are the same?
              value of engine kind c3580 is: 100904, I think the value isn t the same but I m not sure, I need an american technician for confirm it
              again thanks a lot
              best regards
              jerome
              G-SYSTEM
              • teckat
                • 16083
                The Firmware Ver. 92.05 is the same for iR C3580/3580i/3480/3480i/3080/3080i/2550/2550i.
                **There could be an issue with AC compatibility in your country/ Your USA 3480 is most likely set as a 120v
                Your 3580 is
                a 220-240V AC, 50/60Hz
                **For the most part the 3480 and 3580 are the same machine/ take a look at the main plugs for both/ your 3580 is a 220-240v supply/ the USA 3480 is a US standard 120v machine
                The HDD part number>FM2-8258-000
                is the same for>iR C3580/3580i/3480/3480i/3080/3080i/2550/2550i/2380i.
                Pardon me, but Canon France is a jerk for giving you that answer. There are plenty of USA made models overseas in many countries.
                Your 3580 is most likely set as 230v .
                I check the parts manual for>
                iR C3580/3580i/3480/3480i/3080/3080i/2550/2550i/2380i./
                The Different parts between 120v iR3480 and 230v iR3580, are below>
                ALL DAY POWER PCB ASSEMBLY
                MAIN POWER SUPPLY PCB ASSEMBLY
                CONTROL PANEL ASSEMBLY-230V CN/EUR/KR
                PANEL, for CONTROL PANEL-230V CN/EUR/KR
                POWER CORD TERMINAL ASSEMBLY-230v
                CORD, POWER SUPPLY-230V ASIA/EUR/KR
                BREAKER, ELECTRIC LEAKAGE-230v
                FIXING ASSEMBLY-230v
                FIXING FILM UNIT-230
                FAX ASSEMBLY-iR C3580F/3080F/2550F
                FAX PCB ASSEMBLY-iR C3580F/3080F/2550F
                SPEAKER ASSEMBLY-iR C3580F/3080F/2550F
                MODEM PCB ASSEMBLY-iR C3580F/3080F/2550F
                In other words the
                iR C3580/3580i/3480/3480i/3080/3080i/2550/2550i/2380i./are all the same except for listed parts for 3580 230v EUR printer/ there are some different parts for some CN/AU/ASIA countries.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Your 3580 is a 220-240V AC, 50/60Hz
                  You know that might be a good point.
                  • costd
                    • Jan 2008
                    • 409
                    There is a reason they label them a 3480 and 3580
                    Screwtape has hit the nail on the head. The issue is the difference between 60Hz (3480 - US) and 50Hz (Europe). Although you can use a transformer for the voltage - it cannot change the Hz. The motors on the 3480 (in Europe) will turn slower and screw up the timing. Many years ago I had to deal with the Hz issue and the only viable solution I found was to "frankenstine" a UPS system that took in the 220/50 and charged a battery backup unit (not a store bought kind) that fed an inverter that output 120/60. Even that would develop interesting issues every so often.
                    • teckat
                      • 16083
                      not worth the effort/ i gave poster all the info they needed/
                      my suggestion is wherever that machine was received from RETURN IT/ or SELL IT ON E BAY
                      someone in USA will buy for use or parts
