irc 3080 network settings
  • gubsy
    • May 2025
    hi guys,
    how do i configure the network settings on IR C3080?
    cheers,
    gubsy.
  • costd
    • Jan 2008
    • 409
    Additional Functions>System Settings>Network Settings
    It is in the User Manual under Network Settings. Helps to Read The Fine Manual.
    • gubsy
      thanks but when i press "additional functions" (the star in a head) nothing happens...
      • costd
        • Jan 2008
        • 409
        A few things come to mind:
        1. Are you the Device Manager? - if not, call the person that is as they have, for some reason (like keeping users from changes defaults), locked it out.
        2. Is the machine already configured and you are trying to change something? - if so, you could try using the RUI.
        3. If you are not using account management - the control panel may have a problem and you should call a tech.
