cannot install Canon IR5570 with windows 7
  • sikuswo
    • May 2025
    Dear all,
    I need your help.
    I have canon IR5570. my computer use windows 7 32 bit. conection with lan cable.
    That i have done :
    1. Ping canon from PC. success.
    2. Ping PC from canon IR5570. Failed.
    3. I install CanonDriverConfigToolv3_32BIT.exe
    Canon U.S.A : Disclaimer
    success.
    4. Install PCL5e-c_6_v8.70_v6.70_Setup.exe
    failed because the pc does not detect the presence of Canon IR5570.
    now, I cannot print or scan use to canon IR5570.
    What will I do to solve problem?
    Thank you.
    sigid from Indonesia
  • JustManuals
    • Jan 2006
    • 9838
    What version of Windows 7 are you running?
    • sikuswo
      Windows 7 32bit
      • sikuswo
        Dear manuals4you,
        I make personal massage for you but cannot enter becouse your massage is full.
        I need user guide or user manual (Not service manual) canon IR5570 to find solving problem. I have visited to your website, but i didn't get its. Could you give me link the file? I will pay with pay pal.
        Thank you.
        regards,
        sigid
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Originally posted by sikuswo
          Dear all,
          I need your help.
          That i have done :
          success.
          Thank you.
          Are you using a patch cable directly connected to the PC.
          If so, you should be using a crossover cable.
          Just because you can't ping the copier doesn't mean its the driver issue.
          It looks like you have a communication problem.
          • teckat
            • 16083
            Dear manuals4you,
            Thank you.
            regards,
            sigid
            What are Straight and Crossover cable/ info link below>>>
            What are Straight and Crossover Cables
            • JustManuals
              • Jan 2006
              • 9838
              You may have to upgrade your Windows 7 32 bit to Windows 7 Pro. I found a lot of my programs do not run on my new laptop with Win7 32.
              HtH
              Paul@justmanuals.com
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                This is in the connectivity forum too...
                Originally posted by D_L_P
                That's your problem right there, the copier can't talk to the PC. I think Vulkor called it, turn off your firewall and try it. You probably need to add an exception for simple file sharing and printing services.
                • mrfixit51
                  Lead Service Technician
                  • Oct 2008
                  • 1975
                  Did this connection work before, say with windows xp? And now that you have changed to w7 it does not? All versions of w7 should handle basic connectivity the same...
                  • blazebusiness
                    SanDiegoCopierRepair.com
                    • 1250
                    HtH
                    Communication / connectivity issue . No disrespect intended but Upgrading his version of Win 7 will not help this problem at all. Don't waste your time.
                    • D_L_P
                      Self Employed
                      • Oct 2009
                      • 1196
                      Try disabling your firewall like Vulkor suggested.
                      • teckat
                        • 16083
                        Dear all,
                        I need your help.
                        That i have done :
                        success.
                        Thank you.
                        turn off Firewall or>>>>
                        Make sure the firewall has file sharing enabled, and if applicable, add the copier's IP to the trusted zone.
                        also if using ScanGear (Color Network ScanGear), add "SGTool.exe" to the firewall exceptions list.
