7105 to 105
  • davidj7
    • 1107
    7105 to 105
    Hi
    I am planning to replace couple of my iR105's I was told to go for 7105 as replacement . Would anyone suggest that model or am i Better off with 105's
    thanks
    a machine is only as good as your tech : source:screwtape ; the scary one
  • teckat
    • 16083
    Originally posted by davidj7
    Hi
    thanks
    Product : imageRUNNER 105+ /9070 / 85+ / 7105 / 7095 / 7086
    Title : imageRUNNER Comparison Chart
    Question :
    What are similarities and differences between imageRUNNER 105+ /9070 / 85+ and imageRUNNER / 7105 / 7095 / 7086?
    Answer :
    Comparisonbetween imageRUNNER series:
    Items in RED indicate advantages
    Feature
    imageRUNNER
    105+ / 9070 / 85+
    imageRUNNER
    7105 / 7095 / 7095 Printer / 7086
    Print Speed
    105 / 90 / 85-ppm (Letter)
    105 / 95 / 86-ppm (Letter)
    iR Controller Platform
    3rd Generation ImagePlatform
    Canon custom processor (single)
    4th Generation ImagePlatform
    Dual Canon custom processors
    Memory
    512MB RAM
    20GB Hard Disk
    1GB RAM
    40GB Hard Disk
    Resolution
    600 dpi x 600 dpi (Scan)
    1,200 x 600 dpi (Interpoloted) (Copy)
    2,400 dpi x 600 dpi (Interpolated (Print)
    1,200 x 600 dpi (Interpolated) (Copy)
    1200 x 1200 (UFR II and PS Print)
    2,400 dpi x 600 dpi (Interpolated) (PCL Print)
    Paper Capacity
    Std. 4,150 Sheets
    Max. 7,650 Sheets
    Std. 4,150 Sheets
    Max. 7,650 Sheets
    Multi-feed Detection Sensors
    Not available
    Standard
    Finishing/Output Options
    Finisher K1N/K2N, Saddle Finisher-K3N, Paper Folding Unit-C1, Document Inserter-B1, Booklet Trimmer-A1
    Finisher-V1, Saddle Finisher-V2, Paper Folding Unit-D1, Document Inserter-C1, Booklet Trimmer-B1, Puncher Unit-V1, High Capacity Stacker-A1, Perfect Binder-A1, Professional Puncher-A1
    Saddle Finisher capabilities
    3,000-sheet stacking, 100-sheet stapling, 15-sheet Booklets (60 imaged pages), Saddle Stitch Tray capacity 30-sets, Standard 2/3- hole punch.
    5,000-sheet stacking, 100-sheet stapling, 20-sheet Booklets (80 imaged pages), Unlimited Saddle Stitch Tray capacity, Optional Puncher Unit-V1 or Professional Puncher-A1
    Supported PDLs
    Canon controller: Canon UFRII, PCL5e/6, PS3 emulation
    imagePASS-M3: PCL5e/6, Adobe PS3
    imagePASS-S1:
    PCL5e/6, Adobe PS3
    Mailbox support
    Standard
    8,000 total accumulated pages
    Standard
    20,000 total accumulated pa
    ges
    Universal Send / PDF Enhancement Kit
    Option / Option
    Option / Option
    Web Access Software
    Option
    Option
    Secure Watermark Kit
    Not available
    Option
    Canon MEAP
    Standard
    Standard
    Toner Yield
    36,600 Impressions @ 6% (1.65Kg)
    47,000 Impressions @ 6% (2Kg)
    Drum Yield
    5,000,000 Impressions
    6,000,000 Impressions
    • SCREWTAPE
      East Coast Imaging
      • 3396
      The 7105 is a good box.
      I think you would be pleased.
      • davidj7
        • 1107
        i dont think there is much in mechanical differences. Most parts looks the same.
        Thanks guys.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Thanks guys.
          No!
          There's some differences.
          • teckat
            • 16083
            Thanks guys.
            check my post above / there are some
            • davidj7
              • 1107
              i ve told them to bring a machine .let me see.
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                Hi Davidj7,
                To echo Screwtape and Teckat, the iR7105 is an excellent copier, depending on the age of the copier and how well they were maintained.
                • davidj7
                  • 1107
                  thanks again . I will keep you posted once the machine arrives. cheers :-)
                  • Canuck
                    Tech Specialist
                    • 1713
                    Big difference.....bottom line...105 is designed to run 8 hrs/day...7105 is designed to run 16hrs/day. 7105 is built more robust than 105....just look at the difference between the two finishers. A 105 is pretty well an ir600 that runs 105 pages per minute. 105 life is about 15 million,7105 is 24 million according to Canon
                    • teckat
                      • 16083
                      all the news that's fit to print'
                      • davidj7
                        • 1107
                        i run 105's 24 hours a day he he thanks canuck .
