IR2270 2 sided
  • Brian8506
    • 1665
    IR2270 2 sided
    Machine always scans for 2 sided copies but 2 sided is not selected. I think there may be a setting somewhere that needs to be defaulted. TIA
  • teckat
    • 16083
    enter service mode level 2 > COPIER > OPTION > BODY ><SCANSLCT set to "0">.
    If the setting is "1" the feeder will scan the original twice. Set to "0" for single scanning.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      When you mean scanning 2 sided.
      Do you mean scanning as scanning to a file folder or;
      When your just making copies?
      If its when you copy.
      Try initializing your copy or common settings.
      • teckat
        • 16083
        SCREWTAPE/ i think poster means scanner moves twice on same doc/ not a reverse pic up from try/
        if it's just for scanner moving twice under same doc/ that level 2 fix will work for single scan
        set up
        • SCREWTAPE
          East Coast Imaging
          • 3396
          set up
          UMM.
          • Brian8506
            • 1665
            Techkat got it thanks I dont know why it was set to 1 but 0 makes it scan one side unless 2 sided is chosen on copying
            • teckat
              • 16083
              Your Welcome~~~~~~~~~~~~~~~~~~
