irc 3200 e751-1301
  • mujibur
    • 53
    [Error Code] irc 3200 e751-1301
    hi irc
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Originally posted by mujibur
    hi irc
    E751, 1301 means there is an issue with the toner system.
    The color that is causing the issue is the first digit in the sub code.
    That would be yellow.
    • teckat
      • 16083
      hi irc
      E751 The connection of the drum unit /toner container is faulty.
      The mark x indicates color [Y=1, M=2, C=3, K=4].
      000x The connection of the drum unit (at the printer side) is faulty.
      100x The connection of the toner container (at the printer side) is faulty.
      010x Built-in memory writing error in the drum unit.
      110x Built-in memory writing error in the toner container.
      020x Built-in memory data error in the drum unit.
      120x Built-in memory data error in the toner container.
      030x Built-in memory writing error in the drum unit (When the number of retry exceeds the
      specified value)
      130x Built-in memory writing error in the toner container (When the number of retry exceeds
      the specified value).
      u have a defective YELLOW TONER Container or a bad BOOTLEG Yellow Toner Container
      • jiongpao
        • May 2009
        • 414
        Hi, im in need of part catalog of irc3200, having difficulty to order some parts from supplier since we both does'nt know what are we talking like this and that hahahah ... I found out that this kind of model always problem with the internal delivery roller at the left hand side cover of fixing feeder assembly. It melt easily. Will appreciate if someone sent me only the PC of it. Thank you.
        derick_80@hotmail.com
        • SCREWTAPE
          East Coast Imaging
          • 3396
          I believe the part your looking for is this,
          FB6-4862-020- ROLLER, INTERNAL DELIVERY
          • teckat
            • 16083
            Once that roller melts soft, the entire door cover can become warped
            IT IS EASIER TO CHANGE THE EXTERNAL DELIVERY COVER ASS'Y
            FG6-9059-100= EXCEPT RQY,RQZ SERIAL NUMBERS
            FM1-0351-080= FOR RQY,RQZ SERIAL NUMBERS
