irc 3200 e751-1301
  • mujibur
    • 53
    [Error Code] irc 3200 e751-1301
    hi irc 3200 have ya problem e 751 -1301 am reset 1day working after same problem any one help me
  • teckat
    • 16083
    E751 The connection of the drum unit /toner container is faulty.
    The mark x indicates color [Y=1, M=2, C=3, K=4].
    000x The connection of the drum unit (at the printer side) is faulty.
    100x The connection of the toner container (at the printer side) is faulty.
    010x Built-in memory writing error in the drum unit.
    110x Built-in memory writing error in the toner container.
    020x Built-in memory data error in the drum unit.
    120x Built-in memory data error in the toner container.
    030x Built-in memory writing error in the drum unit (When the number of retry exceeds the
    specified value)
    130x Built-in memory writing error in the toner container (When the number of retry exceeds
    the specified value).
    u have a defective YELLOW TONER Container or a bad BOOTLEG Yellow Toner Container
    • mujibur
      • 53
      thak you i chek yello container but some problem thank u tecat
      • SCREWTAPE
        East Coast Imaging
        • 3396
        thank you i check yellow container but some problem thank u tecat
        You checked the yellow toner cartridge.
        Why don't you try another yellow cartridge.
        Is it a genuine canon toner cartridge?
        • mujibur
          • 53
          yes genuine some lock strack m/c customer place 2day want 2 go thak u
          • teckat
            • 16083
            slow down a bit/ simple ??????
            did you replace it with a new yellow toner cartridge ----Yes or No ????
            • mujibur
              • 53
              yes i change yellow cartradge
              • teckat
                • 16083
                what happened/ is machine working ?????
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  With a new one?
                  I guess you should start checking some of the pcb's that we mention.
                  • blazebusiness
                    SanDiegoCopierRepair.com
                    • 1257
                    Ok...so lets review....You had that code come up then it reset and worked for a day & then reoccurred. Screwtape & Teckat are right to begin with the yellow toner. Like Teckat I'm unclear as to whether or not the machine is working now but if its not here is where we go next. This is a problem with toner supply. The atr sensor in the dv unit asks for toner to restore the ratio of dev & toner in the dv unit. Then motor M20 (for yellow) turns and supplies toner restoring the proper ratio. Bootleg toner could give bad readings causing your trouble. The rotation of the toner feed screw is monitored by a sensor. The sensor or motor M20 could be at fault. Have you cleaned the sensor & checked the motor yet? Other possibilities are the drum unit itself or the dev drive assy. How old is that yellow drum unit? Hope this helps. Please post the fix so we all benefit.
