Plz help clc 3200
  • rabib
    • 63
    Plz help clc 3200
    PLZ HELP!!!!!!!!!!!!
    I have problem in my machine clc 3200
    when I change the NVR ( Ver. 70.01c <>Ver. 70.01N ) the machine is printed , but when I change the NVR ( Ver. 70.01c <>Ver. 70.01N ) the machine is not printed
    what is the solution to change the NVR Ver. 70.01c TOOOOOOO Ver. 70.01N ??
    Ihave the sst v4 but i dont have the software
    NB (I dont have the fiery)
  • SCREWTAPE
    East Coast Imaging
    • 3396
    You need software!
    Don't you have it. You said you change software.
    Firmware is not going to change it back to a N or C
    The SST can distinguish between versions on this model.
    In order to have a N chip, there must be a printer kit installed.
    • rabib
      • 63
      thanks screwtape
      irc 3200 >>>>>>>>>Ver. 70.01c
      clc 3200>>>>>>>>>Ver. 70.01N
      I need the firmware for canon irc3200
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Why do you need firmware?
        IRC,CLC.. These are both the same machines.
        Either one can be a v70.01N.
        • rabib
          • 63
          I need the firmware because I have the firmware v70.01c I saw transferred to v70.01n
          I have the clc
          v70.01c the machine is printed
          v70.01c the machine is not printed
          plzzzzzzzzzzzzzzz
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Did this machine print before?
            • teckat
              • 16083
              Originally posted by rabib
              thanks screwtape
              the 3200 with the C Boot Rom should have a Firey connected
              the 3200 with the N Boot Rom should have the Multi-PDL Kit installed / & No Fiery
              u can not mismatch C and N Firmware when updating , the SST will not let you
              did u swap the BOOT ROM's / if so put them back to the correct printers
              *****only on the iRC3220 there is no distinction between N or C version in the Service Support Tool.
              • cableties
                • 35
                You guys are good mentor>>>>>>>>>>>>
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Why thank you.
                  Good name.
                  But I hate cable ties.
                  I refer them as wire ties.
                  LOL.
                  • teckat
                    • 16083
                    techs support each other & others in need ~~~~~~~~~~~~~~~~~~~~~~~~~:>
                    • rabib
                      • 63
                      thanks teckat & cableties
                      I have clc3200 BOOT ROOM c boot room 71.01C (but I dont have fiery)
                      when I connect the SST to update the 71.01c to N (pcl)
                      teh message apear : error to update
                      • teckat
                        • 16083
                        [ATTACH=CONFIG]5335[/ATTACH]
                        [ATTACH=CONFIG]5334[/ATTACH]
                        The C Boot Rom that is used without a Fiery/ is to have the 3200 used as a Copier only .
                        U can not update a C Boot Rom to a N Boot Rom
                        The N Boot Rom only comes in a Multi PDL Kit- A1 for iR3200
                        imageRunner C3200
                        Color Network Multi-PDL Printer Kit-A1
                        There are various items located in the Color Network Multi-PDL Printer Kit-A1.
                        When the Multi-PDL Printer Kit-A1 is sent,
                        inside is the UFR board and Network Boot DIMM .
                        The UFR board and the Network Boot DIMM.
                        The -N- Networking Boot DIMM is necessary for the Canon controller, and the -C- Copier Boot DIMM is necessary for the imagePASS-C1 and the C3200 copier-only model.
                        **DO NOT THROW AWAY ANY OF THE BOOT DIMM’S. The Networking Boot DIMM is necessary for the Canon controller, and the Copier Boot DIMM is necessary for the imagePASS-C1 and the C3200 copier-only model.
                        When installing the Network Boot DIMM, u should place Copier Boot DIMM behind the service cover, inside the front door cover.
                        Service Cover
                        To utilize the Color imageRUNNER C3200 for printing, there are several possibilities.
                        Print functionality can be added to the Main Controller of the copier by installing the Color Network Multi-
                        PDL Printer Kit-A1.
                        Alternately, this functionality can be added by utilizing an imagePASS-C1. These are
                        mutually exclusive items – only one printing kit can be utilized. Both kits provide 10/100Base-T Ethernet
                        connectivity.
                        Color Network Multi-PDL Printer Kit-A1 comes with an UFR Board (Ultra Fast Rendering Board) that needs to be installed in the Color imageRUNNER C3200.
                        This board is installed in the slot on the Main Controller underneath the Ethernet PCB.
                        The imagePASS-C1 requires that an Open Interface Board be installed in the Color imageRUNNER C3200.
                        This PCB is included with the imagePASS-C1 and is also installed in the slot on the Main Controller underneath the Ethernet PCB.
                        Since both printing kits require a different PCB be installed in the same slot of the Main Controller, the printing kits are mutually exclusive – only one can be installed at a time.
                        Network scanning will be possible if either printing kit is installed
                        UNIVERSAL SEND:
                        The Universal Send functionality of the Color imageRUNNER C3200 is enabled by use of the Color
                        Universal Send Kit-A1P. The Resolution Switching Board-A1 is also REQUIRED for the Universal Send
                        functionality.
                        • rabib
                          • 63
                          thanks
                          teckat (*_^)
                          • teckat
                            • 16083
                            • rabib
                              • 63
                              hi teckat do you
                              have some picture for :
                              imagePASS-C1 ?????????
