clc 5100
  • pontiac
    • 420
    clc 5100
    We went from a copier working great to error code E194 0101 after moving copier 30 yards on driveway. I uninstalled and reinstalled primary charge and transfer assembly slid out drum assembly and reinstalled. Still have error. any ideas......Thanks for feedback
    • 16083
    Check if your Transfer Unit is lifting when u turn on copier/ also check to see if u can rotate belt unit by hand/ The belt cleaning blade can also lock up belt movement
    Try to View the registration patterns on the transfer belt ,make sure all of the registration patterns are being transferred. All registration patterns must be correctly transferred to the transfer belt for the machine to adequately read and adjust registration.
    [IMG]file:///C:/DOCUME%7E1/NICK/LOCALS%7E1/Temp/moz-screenshot-5.png[/IMG][IMG]file:///C:/DOCUME%7E1/NICK/LOCALS%7E1/Temp/moz-screenshot-6.png[/IMG]
    CHECK THOSE TRANSFER DRIVER CONNECTORS BELOW
    Error :
    An E194-0101 Code is Displayed on the control panel. During the Warm-Up cycle, the Transfer Bed Assembly engages and the Transfer Belt starts to rotate. While the belt is rotating, a noise can be heard, before the Error Code is Displayed.
    Transfer Driver PCB ---- CHECK THOSE TRANSFER DRIVER CONNECTORS BELOW
