ir c3100 e0020-01a9
  • lightningjeremy
    • Jul 2009
    • 139
    ir c3100 e0020-01a9
    a customer of mine has a 020-01a9 code come up every morning after they wake the machine up. they restart the machine and it runs fine all day. i have replaced the atr sensor with no change in symptoms. please help. thanx
  • SCREWTAPE
    East Coast Imaging
    • 3396
    This error is your yellow developer.
    Has it ever been replaced?
    You can try going into service mode:
    Copier/function/install/sply-h for yellow
    If it helps for a while, then your ok.
    If it comes back, then replace the yellow developer.
    • lightningjeremy
      • Jul 2009
      • 139
      ok, thanx
      • baseball4
        are they using oem toner???? have seen katun toner cause this problem.
        • teckat
          • 16083
          020-01A9/ Is a Developer Issue for Yellow/ and not a Toner Issue for yellow
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            Yes, and no. The ATR sensor is measuring toner concentration in the developer, so toner is the issue. Agreeing with what is being said here, more than likely the yellow developer assembly is long in the tooth, and needs to find it's way to the dumpster...
            • tinnyjay
              • Oct 2009
              • 662
              In ATR control, the detected T/D ratio is
              lower than its lower limit (3%) 3 times
              in succession.
              1-Check on attachment of the developing unit,
              2-Replace the ATR sensor
              "Who loves the roses,must also bear thumbs"
