Canon ir5000 - ScanGear and Windows 7
  • kuby
    • Oct 2007
    • 1409
    What version of Scangear is working with WIndows 7....have a customer that has a ir5000 and windows 7, can not get ScanGear to work. Windows 7 will not see the scanner at all.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Did the program install successfully?
    • kuby
      • Oct 2007
      • 1409
      Yes the program installed OK. Went to the tools and tried to let it find the copier/scanner, then put the IP address in and it still would not find it.
      I am using ScanGear v 2.21
      • tinnyjay
        • Oct 2009
        • 663
        Are you sure you know to do this?
        Have you tried with other Win XP or Win Vista and it worked?
        If yes,try to download again Netgear Windows 7 Version.
        "Who loves the roses,must also bear thumbs"
        • kuby
          • Oct 2007
          • 1409
          NetGear???? And yes I have been installing ScanGear for about 8 years now, but never tried it on Windows 7.
          • kuby
            • Oct 2007
            • 1409
            I have figured it is the Windows 7 - 64bit version that is causing the problem.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Ah, 64 bit
              Yea seen that before.
              Also, look out for this when installing print drivers as well on 64 bit.
              Great find.
              Gald you figured it out.
