CANON IR330 DADF-A1 question
  • repn1999
    • May 2010
    • 310
    How do you get the DADF-A! to feed from the bottom instead of the top
  • teckat
    • 16083
    are u a tech ????
    • Herrmann
      • Jan 2006
      • 792
      Dipsw1, pos 4 and 6 set to *on*
      press pushsw3 one time, led1 should light up
      press pushsw2 5 times, now led2 should light up
      press pushsw3 one time, now led 2 should go dark
      set dipsw1 all to *off* position
      ----> done
      rem.: to reset the procedure, do the same, but press pushsw1 5 times in step3
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • repn1999
        • May 2010
        • 310
        to respond to techat's comment.....yes i am a tech. I work on nearly 100 percent SHARP machines. We took on a few stray Canons because our biggest customer had no service on the few remaining machines they had and werent ready to upgrade them. thanks for the help.
        • teckat
          • 16083
          only reason I ask , Is because when we give instructions about dip switches it confuses end users & techs with little experience
          hope herrmann helped u out
