SST & firmware
  • iden
    • Jun 2025
    SST & firmware
    Dear all, can you tell me, how do get SST and Firmware ?
    Thank you !
  • tinnyjay
    • Oct 2009
    • 662
    There are too many ways!
    First,you must clearify for wich model you need sst & firmware.
    If there is one i have,i can give you for free.
    "Who loves the roses,must also bear thumbs"
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      me l need in canon ir3300 you can explain me more by my email .. mecanographe@gmail.com
      BEST TECHNICIAN . NICE PEOPLE .
      • iden
        thanks before,
        i need sst & firmware for ir 5000 series (ir 5000, 5020, 5000i)
        can i use the sst or firmware without connecting machine (only with pc)?
        • kuby
          • Oct 2007
          • 1395
          The SST needs to be installed on your computer. Then the firmware needs to be installed and registered for the machine. Then you have to hook up the PC to the copier according to the UPgrade procedures for the model you are up grading.
          • aneka copier
            Re: SST & firmware
            kuby : could you send me canon ir5000i firmware, i already have the SST, i'll be very grateful if u can send me by email : anekapc_brandan@yahoo.com
            thanx before
            • zaza
              MECANOGRAPHE
              • Mar 2008
              • 1095
              Re: SST & firmware
              well me too l search this frimware for ir5000i pls if you have sending me by my email : mecanographe@gmail.com
              • immadeofchalk
                Re: SST & firmware
                Hi there, I'm having trouble flashing ir 6020, got erro 602-003 so I connected my copier to my pc with parallel cable, used ALL_HDF to clear everything from the HD but somehow the process failed and got me stuck at "Downloading...", after 10 minutes I decided to turn off the copier and turn it on again but somehow after doing that my copier can't star again, the display is stuck at a black screen and pressing 2 & 8 wouldn't get it at download mode.
                Can someone help or suggest something to do?
                Thanks in advance!
                • teckat
                  • 16083
                  Re: SST & firmware
                  Thanks in advance!
                  First Make sure u have only one version of SST on PC or Laptop --
                  I don't know what u were trying to accomplish -
                  1-install new HDD ?
                  2-upgrade printer ver. ?
                  3-relaod/overwrite currant printer ver .?
                  what ver. of iR5020 Firmware do u have registered in SST ?
                  if u intend to upgrade the iR5020> u don't select ALL_HDF
                  if u are replacing the HDD> u first need to FORMAT it under HD FORMAT
                  the latest version for iR5020 SERIES is v59.51-
                  in that version
                  The ALL & ALL_HDF files have not been created or added to the System Software due to issues during testing of the firmware. Please flash the software using the “Single” link in SST
                  there is no SINGLE link selection in v59.51 in latest SST > u use the START ASSIST mode in SST middle menu
                  The ALL file is meant for re-installation of software onto a machine that already contains a working system (i.e. Download Mode in Service Mode can be entered).
                  The ALL_HDF is intended for use when a HDD has been formatted with HDFormat or when a new service part HDD has been installed (i.e. there is no working system installed).
                  remove cable & shut down SST
                  now try this > power off printer> hold down 1 & 9 keys>while holding keys>power up printer>keep holding 1 & 9 until it starts to DEFRAG (white boxes falling) wait until it finishes > either it will go into DOWNLOAD > that is good / if e602 pops u may need a new HDD/
                  if u are lucky to see DOWNLOAD> power off printer >power back up printer
                  let me know what u are trying to do ????
                  • hamid5566
                    SST & firmware
                    Hai i am very new to this site and i need canon IR3300 SST & firmware towards format and install to my hard disk
                    my English is very poor never mind
                    Hameed from India,
                    my mail id is hamid5566@gmail.com
                    • JustManuals
                      • Jan 2006
                      • 9838
                      Re: SST & firmware
                      1st post and he wants something. What are you offering in return? Your gratitude is not enough.
                      • suniljeurkar
                        Re: SST & firmware
                        hi iam new to this site ... i need firmware for IR2200 N type boot rom .. please help me ...!!
                        • JustManuals
                          • Jan 2006
                          • 9838
                          Re: SST & firmware
                          1st post and he needs something, how very surprising!
                          • Eric1968
                            • 2458
                            Re: SST & firmware
                            Asking (or begging) for firmware on your first post won't work here... If you can help somebody out, you can expect something in return.
                            • sham.panhale
                              • Sep 2012
                              • 54
                              Re: SST & firmware
                              Dear Sir , I need SST & Firmware for Canon IR7086 .
                              Do u have it ? Can you send me ?
                              Sham.panhale@gmail.com
