IR3300 E355
  • harnrak
    • Aug 2009
    • 32
    [Electrical] IR3300 E355
    when i turn on my copier, it appears E355. i had already cleared all Ram and error E355 but nothing gonna change. Once i tried to replace counter PCB, it worked. but how can i do with my old counter PCB and how will i know the old counter PBC is lose or not. Thank in advance
  • rosaro75
    • Mar 2009
    • 86
    when changing serial no. board and counter board if got this error first you remove both serial and counter board. now you get E350 error. goto service mode copier>function>clear>con-mcon, con-dcon clear it too. if again same problem occur take sram backup from running machine and copy it to the machine.
    note: sram back must be taken in download mode by pressing 2&8 while switch on the the machine. the sram backup taken in normal download mode will not work.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      NOTE:
      Counter pcb's should not be swap.
      • tinnyjay
        • Oct 2009
        • 663
        Error code E355 means "clear".
        You must clear :
        E355-CLR
        PWD-CLR
        Use it to clear the password of the system administrator in user mode.
        Using the Mode
        1) Select <PWD-CLR> to highlight, and press the OK key.
        2) Turn off and then on the main power switch.
        ADRS-BK
        Use it to clear the address book data.
        Using the Mode
        1) Select <ADRS-BK> to highlight, and press the OK key.
        CNT-MCON
        Use it to clear the counters for servicing on the main controller PCB.
        Using the Mode
        1) Select <CNT-MCON> to highlight, and press the OK key.
        CNT-DCON
        Use it to clear the counter for servicing on the DC controller PCB.
        Using the Mode
        1) Select <CNT-DCON> to highlight, and press the OK key.
        MMI
        Use it to clear the backup data for the user mode settings (specifications, ID
        mode, group ID, mode memory, etc.).
        Using the Mode
        1) Select <MMI> to highlight, and press the OK key
        CARD
        Use it to clear the card (group) ID-related data.
        Using the Mode
        1) Select <CARD> to highlight, and press the OK key.
        ALARM
        Use it to clear the alarm log.
        Using the Mode
        1) Select <ALARM> to highlight, and press the OK key.
        SCANLAMP
        Use it to check the scanning lamp for activation.
        Using the Mode
        1) Select <SCANLAMP> to highlight, and press the OK key.
        2) The scanning lamp goes ON.
        3) Press the Stop key to turn off the lamp.
        After you clear these counters,and is still E355,you can think your PCB is faulty.
        "Who loves the roses,must also bear thumbs"
        • SCREWTAPE
          East Coast Imaging
          • 3396
          You must clear :
          PWD-CLR
          Using the Mode
          ADRS-BK
          Using the Mode
          CNT-MCON
          Using the Mode
          CNT-DCON
          Using the Mode
          MMI
          Using the Mode
          CARD
          Using the Mode
          ALARM
          Using the Mode
          SCANLAMP
          Using the Mode
          What does all this have to do with a E355!
          • teckat
            • 16083
            that is a waste of time to post CLEAR INFO/
            techs need to know that u CANNOT SWAP COUNTER PCB'S
            • tinnyjay
              • Oct 2009
              • 663
              [ATTACH=CONFIG]5421[/ATTACH]
              Its in your hand to loose or not to loose time teckat!
              Somebody's copier shows an error code and i told him what does this code means.
              I dont know where is the problem here?
              And i am very sure if he clear this counters,E355 will goes.
              • teckat
                • 16083
                the reason u receive an E355 is brought upon the machine by the tech.
                the machine does not wake up and say " how about an E355 code today"
                other clear info has nothing to do with E355
                where did u say what E355 means in your response ???
                • tinnyjay
                  • Oct 2009
                  • 663
                  Where did i say?
                  Where you learned about copier error codes?
                  In school?
                  No,you learned about these codes in Service Manuals and i did the same.
                  • teckat
                    • 16083
                    don't believe everything u read
                    • Alan Aya
                      You cannot simply change the counter board or the serial number board. It has to go in ONE SET.
                      • tinnyjay
                        • Oct 2009
                        • 663
                        You are free to do whatever you want!
                        • teckat
                          • 16083
                          You can try and modify all the machines u want, in your country no one gives a crap/ keep using you bootleg supplies
                          try that in USA, and you end up in Jail
                          all Colors machines have a yellow dot matrix pattern in various columns, in a Binary-coded-decimal ,imprinted on every print/or copy that comes out of it.
                          the sequence shows - A Serial #_Canon ID #_& or a Manuf.ID#_Time_Date_Year_Hour_Minute
                          - when prints or copies were made
                          any time you purchase/ Parts-Toner-or Starter that info is recorded and sent to government by the Supplier and Manufacture of said items.
                          Believe it or Not they know the location of every Color Printing Product.
