Canon Imagerunner C3220
  • dannyas
    • Jun 2025
    Ok Hahaha so I can't get this to work I've had this copier in here forever had it working long before but no luck now...
    So I know its a Canon Imagerunner C3220 with a C1 server on the back
    So I checked the crossover cable it works fine the ethernet cable to my router is great and the green light on the server on back copier light up and blink
    The red led 3-2-1-0 Ok so 2-1 are light red....
    And when I go to the menu and look at printer it says wait and doesn't go on from there....
    Any Ideas I can't find it on my router settings
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    I assume you need to reload the C1 system software.
    The wait... screen is what gives me that indication. If after 5 minutes it does not change, my first step would be the software.
    • teckat
      • 16083
      Does the 3220 stay in initial rotation , during Please Wait message ??
      If it does> check your Fuser Temp/ how old are the DRUMS ???
      U can also remove and re-seat the Open Interface Board
      • dannyas
        Hmmm if I have to reload c1 system software how do I do that and where do I get it?
        and when it says wait a moment it does it forever.... how do I know if it stays in rotation?...... what is Fuser Temp..... What are the drums?
        It makes copies great but just want to connect to my router...
        • mrfixit51
          • Oct 2008
          • 1975
          The C1 software came on a disk with the C1, called system software. Locate one if you do not have one.
          If the C1 does not boot up, or the copier cannot "talk" with it, you get the wait... That is why I suggested reloading system software.
          If it makes copies, the fuser has reached operating temperature, if the copies look good, don't worry about the photo drums right now.
          I would suggest you acquire the manuals to service this copier, so you will be better prepared to take care of it, and gather some knowledge of this device to make it easier for you to fix it...
          • teckat
            • 16083
            This poster is not a tech/ or he would know what Drums are/ what a fuser is/etc.>etc.>
            dannyas/ u better call for service on your 3220
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1250
              Try disconnecting the C-1 & configure to connect directly to the C3220 if you cannot locate the C-1 system software disk.
              • SCREWTAPE
                East Coast Imaging
                • 3396
                The dimms(memory,ram) can also cause boot up issues.
                But, if you not sure about what steps to take to approach this issue, I would call a trained tech.
