Canon IR3380i
  • banderas6
    [Error Code] Canon IR3380i
    Canon IR3380i, department ID and Password Removal
    Can anyone help me remove the Department ID and Password?
    I just bought a slightly used Canon IR3530 unit, when I turn it on, the display goes directly to the department ID and Password input...sadly No body knows the the codes.
    Is there a default or universal codes? thanks in advance.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    You can do this in service mode....are you a tech ?
