canon ir 4570 e202-002
  • harsh
    • Jul 2010
    • 25
    Can any one say how to rectify this error
    is it related to home position sensor cuz i have tried 2 solve it by replacing home position sensor with new one
  • cableties
    • 35
    cis home position or reader controller pcb is faulty
    • montana
      • Aug 2008
      • 393
      hi...there is an error in the detection of the CIS home position..as recomended in the sm.disconect then conect the harness conector..replace the following as necessary
      scanner home position sensor
      scanner motor
      reader controller PCB
      i wish you good luck
      • SCREWTAPE
        East Coast Imaging
        • 3396
        What does the CIS do when you power on the 4570?
        • teckat
          • 16083
          check that crapy harness connector
          When u pull CIS back away and power up does motor move it forward or attempt to move ???
          did u check J506 for CIS HP SIGNAL> PS503 on Reader pcb.
          J506 copy board cover open/closed sensor; connects to the CIS HP
          sensor
          R-CON
          ADDRESS>
          P008
          0- Lamp ON signal 1:ON
          1- CIS drive ON signal 1:ON
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            I had a 2270, very early in it's life pop that code. Optics never were driven home. Reader board was my fix...
