Canon IR4570 Sharescan Essentials / scan to e-mail Netowrk folder alternatives
  • johnm@ucopier.com
    • Jun 2010
    • 46
    We are debating the installation of Sharescan or another MEAP enabled software technology to run on the Canon IR227/3570/4570 series machines. What would the community suggest in terms of simplicity? both from an installation standpoint and an end-user point of view?
    Also, does anyone have the technical documentation available to them with the steps to install ecopy Sharescan onto the machine?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    This machine is discontinue. You can probably still get these options however.
    If scanning to email or file folder, I would highly recommend, Universal Send Kit-B1 for your needs.
    Here is the item code.
    Universal Send Kit-B1 --9594A002AA
    Call a Canon authorized dealer near you.
    There definitely out there in Chicago.
    Been there for training a while back.
    Good luck.
    • CanonSco
      Man About Town
      • Jul 2010
      • 368
      Agreed. In terms of simplicity the Send Kit is your best bet over SSOP Ecopy.
      Yes, I am a nerd.
      Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
      • johnm@ucopier.com
        • Jun 2010
        • 46
        Ok, I think that would be the way to go as well, can the B-1's typically be found on the used market?
        I was also curious what models directly replaced the 2270/3570/4570 ? were there any models in between these and the new Advance Models?
        • SCREWTAPE
          East Coast Imaging
          • 3396
          There are the ir3245,ir3045.
          Not to sure if you can find B1 used. I believe its licensed activated.
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            Originally posted by SCREWTAPE
            I believe it's license activated.
            Ding, Ding, Ding, Ding, Ding,
            Right once more, it is licensed through Canon's LMS system. I checked eBay and found none. There are many Canon dealers in the Chicago area, you might find one sitting on an unsold kit.
            • jrbucfan
              • Jul 2010
              • 11
              Is the Multi-PDL Kit E1 also required if it had a Fiery previously? One of my IT guys is trying this for a old customer and I haven't done one on this machine for a while.
              • SCREWTAPE
                East Coast Imaging
                • 3396
                If it had a fiery previously then that's how they use to print.
                The answer would be, yes it would need a printer kit in order to print or unless you still have the fiery.
                There both different and the two don't work together.
                You would either need one or the other if you want too print.
                • johnm@ucopier.com
                  • Jun 2010
                  • 46
                  Where can I find a canon timeline of product releases? Was the release schedule ?? (2270, 3570, 4570) -> (3025,3035,3045) -> (3225,3235,3245) ?
                  • teckat
                    • 16083
                    imageRUNNER 2270/2870/3570/4570= y2004
                    imageRUNNER 2230/2830/3530/4530 =y2005
                    There are differences between the xx30 Series and the xx70 Series:
                    Differences in System Software
                    Differences with System Configuration
                    Differences of the Print/Transmission Options
                    There are now three (3) types of Boot ROMs available for the xx30 Series*:
                    �� C = Copy only
                    �� P = UFR II
                    �� H = UFR II and PCL
                    *There are no N type Boot ROMs with this series!
                    Differences with the Operational Panel
                    Differences in User Mode
                    Changes in the Hard Drive (HDD) and SDRAM
                    Paper Pickup/Feeding System
                    Functional Differences in the Power Supply
                    Control Panel Unit
                    Changes in the Electrical Parts Layout
                    Some Part Differences
                    imageRUNNER 3225/ 3230/ 3235/ 3235i/ 3245/ 3245i = y2008
                    These copiers are based on the same platform as the imageRUNNER 4570 & 3045 series.
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      Sorry for the late reply.
                      I believe Ticket broke it down for ya..
                      • johnm@ucopier.com
                        • Jun 2010
                        • 46
                        So where do the 3025 3035 and 3045 fall into this ? 2006-2007?
                        • teckat
                          • 16083
                          imageRUNNER 3045/3035/3030/3025 = Late 2006/2007
                          The imageRUNNER 3045 (Segment 4), imageRUNNER 3035 (Segment 3)
                          and the imageRUNNER 3030/3025 (Segment 2) are Black & White devices
                          with print speeds of up to 45 ppm (pages-per-minute), 35 ppm, 30 ppm, and
                          25 ppm respectively featuring the MEAP (Multifunctional Embedded
                          Application Platform) enabled imageRUNNER controller with advanced
                          capabilities
                          Certain optional software features are pre-installed on all new units, and in
                          order to activate the software programs, the feature must be licensed through
                          the LMS server. This replaces the need for additional hardware or dongles to
                          activate new software. Refer to the LMS section herein for further details.
                          The imageRUNNER 3045/3035/3030/3025 devices offer a DADF (Standard
                          with imageRUNNER 3045/3035, Optional on the imageRUNNER 3030/3025)
                          with a 50-sheet paper capacity and a dual 550-sheet front loading paper
                          cassettes that can accommodate paper sizes up to 11" x 17" and 17 lb. - 20 lb.
                          Bond in weights. These devices can perform auto duplexing with paper
                          weights ranging from 13 lb. - 32 lb. Bond. Users can also add a cassette
                          feeding unit that provides two more 550-sheet cassettes and a 2,700-sheet
                          paper deck for increased paper capacity of up to 4,950 sheets for
                          uninterrupted productivity.
                          • goldencup
                            • Nov 2008
                            • 366
                            Re: Canon IR4570 Sharescan Essentials / scan to e-mail Netowrk folder alternatives
                            �� C = Copy only
                            �� P = UFR II
                            Control Panel Unit
                            Just want to say thanks for this info now i know i have 2 Copy only, 2 UFR II and PCL, and 1 UFR II IR4570 machine, (which means i can only have 3 printers )
                            i would like to ask about the scanner, i have one machine (the one with P Boot ROM) has also a fax and a universal send kit. It can Scan to SMB right? I try to scan but a message always appear (see image).By the way, Delayed Sent is not set. Also I can't access the web interface, though there is a reply on the ip address when i ping it.
                            • teckat
                              • 16083
                              That's a mystery
                              Web Access Software kit needs to be installed.
                              Press the [--->] right arrow button on the copier's display screen until you see [Web Access]
                              Memory Sending
                              All of the originals to be sent are first scanned into memory, then sent. This means that you do not need to stay near the machine once the originals have been scanned. The memory can hold a total of approximately 8000 pages of sent and received documents.
                              Direct Sending:
                              The machine sends each page of the document to the destination as it is scanned, without storing the document in memory. Use 'Direct Sending' when the memory is full, and you still need to send a document.
                              With 'Direct Sending', you can send a document of 2 or more pages only when using the feeder. You can only send 1 page at a time when you place your original on the platen glass.
                              You can specify only 1 destination at a time for 'Direct Sending'. 'Memory Sending' is automatically set when multiple destinations are specified.
                              'Memory Sending' is automatically set when using 'Delayed Send'.
                              To enable or disable 'Direct Sending' mode for a fax job on most fax capable imageRUNNER models:
                              1. On the Send tab, specify the fax destination.
                              2. Press the [Send Settings] button in the lower right hand corner of the Send tab.
                              3. Press the [Direct] button to set or cancel 'Direct Sending' mode. If [Direct] is not selected, then 'Memory Sending' mode is used.
                              4. Select any other desired options and hit [Done].
                              5. Press the [Start] key to send the fax.
