iR3300 - just wont print via computer's parallel.
+ More Options
Posts
  • velocd
    • Aug 2025
    Good day,
    Our company replaced one of our older copy machines, the iR3300, for another brand from a different service company. We've moved the iR3300 to another office that could use it, and have connected it directly to a computer via parallel.
    This computer is running Windows XP. I installed the printer via LPT1 with the latest PS3 drivers from usa.canon.com.
    When I print a test page from the PC the iR3300 reacts with its usual processing noise, but then does nothing. The curious thing is for about 3 seconds after submitting a test print the print job will show up on the print jobs interface on the iR3300 LCD, and then it disappears as if it were processed--but nothing prints. There are no error messages. The printer is good on toner and has paper. The copier works, so I know the printer can print. The only interface on our iR3300 is parallel port, there is no network card installed nor do we have one, so I can't connect the computer to the printer via network.
    We have no contract anymore with the service company that provided our iR3300 (Ikon), they actually left town. Our new printer isn't a Canon and the service company doesn't do Canon. Needless to say, I'm left to my own devices to get this thing working via LPT1. I'm a IT worker/programmer, but I'm unfamiliar with advance copy machine servicing. I can learn quickly about but I'm having trouble finding instructions on how to service the iR3300. From what I've researched I may need to update my firmware to print via LPT1, but I don't know where to find the firmware or how to update it.
    Here's some details about our iR3300:
    Model: iR3300
    Main Board Version: 7
    Controller Version: 3301.1029.1001
    Scanner Version: 701.601
    Fin Version: 105
    Serial: MPH35550
    Troubleshooting:
    - Tried tweaking every interface I could find on the iR3300 LCD, to no avail. I'm aware there is a "Service Mode" for these copy machines, but I don't know how to access it or even what to do once I'm inside.
    - Checked hardware.
    - Rebooted.
    - Tried a different parallel cable.
    - Tried different drivers and older drivers. Does it matter if I use PS3 or PCL by the way? I realize they're page description languages (PostScript3 and Printer Command Language), but I'm not sure what is or isn't compatible between the PC and the copy machine.
    - Tried 2 different computers, Windows XP and the other Windows 7.
    - Tried adjusting software printer settings from the computer's end.
    If anyone can help or walk me through the steps to print via parallel I would greatly appreciate it. ;-)
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    I believe ( I maybe wrong and will be corrected by a canon tech) that the parallel port was a service port for firmware updates not for printing. It uses usb (if on the machine) or network.
    Was it printing at the original location?
    • betinoman
      hi velocd
      first of all, sorry by mi english, i am from monterrey mexico.
      long time ago, i had the same problem, the costumer was very ungry, we have to install a network card,because the pararell dont work, in service mode none item for these problem, so you have to search in copier option (*) some item that said something abot pararell, in this case, i activate thes option and the copier start to print in this port, let me check in one ir, and i post back, whith the exactly route, to resolve you problem, ill posting tomorrow at this time.
      • sgcopiertech
        iR3300 machines can print via parallel port (LPT)
        the most probable cause is that just your machine is not equipped to print.
        please make sure that the machine has a N or H boot rom.
        press * 2 8 *
        press copier
        press version
        check your boot rom vesion
        if you see a C behind the version i.e. ( xx.xxC )
        then your machine would not be able to print at all.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Your gonna need a printer kit.
          Network Multi-PDL Printer Kit-C1
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            Sound advice being offered here,, my question is this, in it's previous usage before it was moved, was it being printed to??
            The Multi-PDL Printer Kit-C1 included boot rom "n" as well as a network card. I always took it for granted that if there was no rj45 port on the copier that it was a standalone copier, and did not have print capabilities.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              I believe there is also a 128MB memory stick that comes along with the printer kit.
              • velocd
                I don't believe it was ever printed to, we used it as a copier only. I just assumed because it had a parallel port it could be connected to a PC and printed to, I didn't realize the port was only for updating firmware. :P
                I entered service mode and the rom is C, so my only option is the printer kit? Where is a good place to buy that affordably?
                It's this I assume:
                Canon Network Multi PDL Printer Kit C1 for IR2200-3300 - eBay (item 290447921674 end time Jul-23-10 05:13:12 PDT)
                • mrfixit51
                  • Oct 2008
                  • 1975
                  The parallel port is not only for upgrading, it can be used for printing also, but only after the print kit is installed. It needs to be enabled under the printer settings.
                  The link to the eBay item appears to be what you need as well as a decent price.
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    It has been quite a while since i set up a 3300 as new,,
                    I just checked the service manual for the print kit, it only shows the boot rom and the nic in the kit...
                    The original configuration sheets used by sales may have some answers, I do not have access to those.
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      I could be confuse with the IR5000/6000 series. I remember one of them required a stick.
                      • Peter Sim
                        • Sep 2008
                        • 445
                        For iR3300 ,128MB memory stick should be good enough,unless you need to do a lot of job build.
                        • bnmand
                          • Sep 2008
                          • 383
                          Network printing makes it easy to print from any device on your network. You can also pull scan in B&W over the network. Getting a network kit installed is well worth it. From just a photocopier, to a photocopier, printer and scanner. I use Adobe Acrobat with the Canon Network ScanGear Tool to scan.
                          Note that when you get the network kit installed you'll need to get the firmware on the copier upgraded via SST to install drivers for printing and other things to get the copier working with the new hardware (be sure not to install drivers for stuff you don't have - if you don't have a FAX kit then don't install the drivers for that).
                          • Tefao
                            • Jul 2023
                            • 13
                            Re: iR3300 - just wont print via computer's parallel.
                            Greetings.waited for your response as concerns the above. please i still got similar problem, and wish to know of your solution
                            Originally posted by betinoman
                            hi velocd
                              doubt you will get a fix from this thread... last post in it was in 2010.
                              lemme suggest you start a new thread in the proper machine forum.
                              list model#
                              any work done on it
                              a PDF of the config page would be helpful
                              list everything you have tried w/ results
                              list any errors received
                              list model of PC
                              list Operating system version
