how to format d hdd of ir 4570/3570/2870
  • harsh
    • Jul 2010
    • 25
    how do we format d hdd of ir 2870/3570/4570 is dere any separate sst or a different procedure we cannot use d bi-centronics cble den how do i do it
  • teckat
    • 16083
    Why do you want to format this HDD ??
    U need the Canon SST Tool & the iR4570/3570/2870 FIRMWARE loaded in the SST -
    • harsh
      • Jul 2010
      • 25
      I dnt want 2 format it jst gathering info
      • teckat
        • 16083
        SERVICE SUPPORT TOOL:
        The SST System Software file is for use with the Service Support Tool (SST), and the
        USB System Software is for use with a USB Flash Drive.
        USB System Software
        Flashing via a USB Flash Drive has been available previously for some models. This file format does not
        change the scope of the models which allow this flashing. However, this file format does streamline the
        process in preparing the USB Flash Drive.
        • The size of the file will be approximately 30-40% smaller than the .exe because all language and RUI
        language files other than English have been eliminated.
        • When extracting the USB file, it will automatically be placed in the following directory: C:\Canon File
        Folder\SST System Software Folder\USB Files. The File can be moved directly to the USB Flash
        Drive using standard Windows functions. No other preparation is required.
        • Multiple System Software versions can be placed on a USA Flash Drive. (Note that this depends on the
        USB memory size and the size of the specific System Software.)
        SST System Software
        Preparing System Software files for the Service Support Tool
        1. Download the series model file.
        2. Execute the series model file. This will place the file in the following location: “C:\Canon File
        Folder\SST Service Support Tool Folder\SST Files”.
        3. Start the Service Support Tool (SST) and select “Register Firmware”.
        4. Right click the C: folder on the list and browse to the following location: “C:\Canon File
        Folder\SST Service Support Tool Folder\SST Files\ Folder>Model of Printer.
        5. Click the search button and the Service Support Tool (SST) will search that folder for the
        series model system software and propagate in the right of the SST screen.
        6. Click the “Register” button to install the series model system software.
        7. As the software is installing, the progress bar moves across the SST and OK is displayed on
        the right of the file installed.
        Loading System Software to the USB Stick
        1. Download the USB System Software of the series machine from the Canon eSupport Website.
        2. Click the Executable file and the file will extract to the following location: “C:\Canon File
        Folder\SST System Software Folder\USB Files”.
        3. Open the folder to show the Series folder and 3 HD-Format files.
        4. Copy the series folder and 3 HD-Format files to the USB stick and the USB stick is ready for
        flashing the specific series model.
        5. Turn on the copier by holding the 2 & 8 keys to place the specific series model to Service
        Mode.
        6. When Download Mode is displayed on the control panel LCD display, insert the USB stick into
        the USB slot of the series model.
        7. When the menu is displayed, follow the instructions indicated.
        • costd
          • Jan 2008
          • 409
          Good info, but unless I am even more wrong than usual, that series cannot be done with USB.
          Question is, are you really trying to format the hard drive AND install the latest firmware (requires SST) - or just clear and initilize the user data and settings areas (does not require SST)?
          • SCREWTAPE
            East Coast Imaging
            • 3396
            You would need a crossover cable in order to connect to the 4570/3570/2870.
