CLC4000 Error Code E260-0002
  • phollawat Chaimoonchuen
    • Dec 2007
    • 71
    [Error Code] CLC4000 Error Code E260-0002
    I have copier canon clc4000. Now it's show error code e260-0002. Somebody can help me.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Check the fuses or could also be power supply. Check your power supply voltages. I think that model also had issues with a connector on the hopper if you plugged in the wrong wire.
      • 16083
      E260 0002 Error Code
      Check for 24 VDC at front door interlock SW1.
      Check 24 VDC outputs at DC Power Supply, Connector J5338 (pin 1 and 2), J5339 (pins 1, 3 and 4) and J5313 (pins 3, 5 and 6). Replace DC Power Supply, if missing any of the 24 VDC outputs.
      + check below
      Product : CLC3900/CLC3900+/CLC4000/CLC5000/CLC5000+/CLC5100 Title : E260 0002 Error :
      This error may occur after replacing either the machine side or hopper side connector J6217.
      Workaround :
      Two 7-pin connectors (one blue and one white) plug into either the machine side or hopper side connector J6217. If the blue and white connector are switched during connector replacement, fuse 5611 will blow on the dc fuse pcb. Fuse 5611 (5A) supplies 24v through connector J5610 to the dc controller connector J2221. See photos for proper connections:
        • Dec 2007
        • 71
        Thank you very much
