How to change language on iR5570 ?
+ More Options
Posts
  • Dedy.P
    • 67
    Hi guys, anyone know how to change iR5570 Language, becouse my copier language is jerman and i want to change it to english ?
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    COPIER > OPTION > BODY
    CONFIG
    Use it to select multiple firmware items stored on the hard disk and
    switchover country, language, machine type, and paper size configuration.
    Procedure
    XXYYZZ
    XX: country (JP); YY: language (ja); ZZ (00): machine type; AA (00):
    paper size configuration. The indications will be in keeping with the
    following: COPIER>DISPLAY>USER>LANGUAGE.
    (The notations in parentheses indicate defaults. The country and language
    notations are for indication only.)
    1) Select <CONFIG>.
    2) Select the appropriate item to highlight, and press the +/- key.
    3) See that each press on the +/- key changes the selections in sequence.
    4) When you have made all selections, press the OK key.
    5) Turn off and then on the main power switch.
