iRC3220 error code E602-0202
  • Blues Guy
    • Aug 2009
    • 216
    [Error Code] iRC3220 error code E602-0202
    Good day guys,
    Would like to get some tips to troubleshoot these iRC3220 with the code E602-0202.
    I have changed the HDD but still the same problem.
    Any idea guys that can you advice me ?
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Workaround :
    Try doing this first:
    1) Service Mode/Copier/Function/System/Chk-type/ 1 / ok.
    2) Then Hd-clear/ ok.
    3) Turn machine off and on and let machine reboot.
    Also could be the main controller board. There could also be a bad SRAM pcb that can cause this problem but if that is the case you might have trouble getting that pcb.
    Note: The SRAM PCB is a Controlled Item and must be ordered through Engineering Service. You cannot, under any circumstances, swap it from another machine since it will cause a mismatch with the Counter Memory PCB.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      May I ask what exactly you did, when you refer to "changing the hard drive"?
      SST to format the hard drive and then loading the system software should resolve almost every 602 error out there.
      As Blaze referred to, the main controller, or the ribbon cable, can also give you this error. I have replaced in excess of 50 hard drives for 602 errors, and not one of those was ever due to the main controller.
      More info on your procedure please...
      • nivssluck
        • May 2008
        • 228
        Originally posted by blazebusiness
        Workaround :
        I always swap (change) SRAM pcb when my iR c3220 hangs up with no problem.
        • teckat
          • 16083
          You keep posting More False info>>>
          SRAM PCB'S Can never be swapped in the 3220/ I have worked in Canon Engineering .
          The SRAM PCB is a Controlled Item and must be ordered through Engineering Service. You cannot, under any circumstances, swap it from another machine since it will cause a mismatch with the Counter Memory PCB. Please contact the Canon Technical Support
          • teckat
            • 16083
            Originally posted by Blues Guy
            Good day guys,
            E602_0202
            The partition FSTDEV is faulty.
            File system (logic) error: error detection
            by check processing; mounting failure
            FSTDEV -May be formatted in normal mode
            FSTDEV and FSTPDEV retain image data as it accumulates while DOSDEV and
            DOSDEV2 retain its associated data; these 4 partitions, therefore, must be formatted at the
            same time. To do so, select FSTDEV using the SST.
            The actual formatting of FSTDEV and PDLDEV takes place when the machine is started
            up the next time, and it takes as long as the following:
            FSTDEV: 2 min (approx.)
            PDLDEV: 5 min (approx.)
            all partitions: 7 min (approx.; i.e., FSTDEV + PDLDEV)
            The times vary according to the state of the HDD, and the progress of formatting is indicated
            by means of a progress bar.
            Formatting of DOSDEV4 requires the use of the SST.
            • fosg2000
              • 8
              ImageRUNNER c6800 error code E602-0202
              got this error on my ImageRUNNER c6800
              any hepl
