e020-0160
  • jiongpao
    • May 2009
    • 413
    e020-0160
    Hi all, may i know what is the problem for this code in irc3200? sorry lack of irc3200 SM
  • teckat
    • 16083
    xx60
    The developer concentration
    target value is faulty (set when a
    new drum is fitted; the value is
    extremely small).
    The fault occurs when an image is being
    formed. It is detected when toner supply
    operation is started.
    Also Make sure the toner shutter on Yellow drum is not damaged
    IRC 3200 / IRC 3220 / IRC 2620 E020 Sub Code XX60
    Check the Yellow toner feed motor operation. Look at picture for correct operation/ check in service mode.
    (Level 1)
    Key up machine/have door open>remove Yellow Drum- preform motor operation below
    COPIER>FUNCTION > Part check>MTR
    Used to specify motor for operation check.
    (Range: 1 to 25; 18 and above are reserved.)
    Operation method-
    1) Select this item.
    2) Enter the desired motor code on the numeric keypad.
    1: Drum ITB motor M1
    2: Toner container motor (Y) M20
    3: Toner container motor (M) M21
    4: Toner container motor (C) M22
    5: Toner container motor (Bk) M23
    The part number for the toner cartridge drive assembly is FG6-8999-000.
    * The assembly is more cost effective than the motor.
    Top rotates COUNTER CLOCKWISE
    Bottom rotates CLOCKWISE
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Replace your yellow drum if this code continues.
      • jiongpao
        • May 2009
        • 413
        yellow drum changed and problem fix thank you
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Way To go..
          Thanks for posting back.
