7105 E500
  • davidj7
    • 1107
    7105 E500
    I am getting E500-001 on 7105. The code is not listed in the Service Manual. What does the error mean.
    a machine is only as good as your tech : source:screwtape ; the scary one
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Come on David!
    That's a finisher error code.
    You would have to look in a finisher service manual for info.
    This a communication error probably.
    Turn off everything and reboot by putting the finisher first then the main unit.
    If this doesn't work check the finisher controller pcb for now.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Actually , that code is not in the finisher manual either. So to clear up that lack of info - It is a Finisher Communication Fault.
      First visually check all cables and connectors .
      Check the power coming from the power supply of the finisher. 5volts brown wires / 24 volts red wires.
      Check the connection of the Arcnet cable and that it is installled correctly. Good luck - Blaze
      • davidj7
        • 1107
        screwtape: I do agree with you i am getting old. ha ha
        anyway i did check the finisher fault codes in the manual they start from 501 .
        blaze: i concluded its a finisher PCB error. I have replacement board on the way.
        I will keep you guys posted.
