Canon CLC E020-02F1
  • Metro Kari
    • Jun 2025
    [Error Code] Canon CLC E020-02F1
    Hi All - started having problems last week, copier would run 5-10 copies and then stop and give error code E020-02F1. Message said to turn machine off then on - once it warmed back up I get another 5 copies and then code again. Seems to be getting worse - is it a sensor with the cyan?
    Thanks for any help!
  • roho
    • Mar 2009
    • 844
    What model clc? I doubt it's just a sensor. You either need to replace the cyan drum unit, or replace the developer-depends on the model.
    • Metro Kari
      It's a clc 5000
      • roho
        • Mar 2009
        • 844
        Ouch! Try removing the cyan dev, drum. You may be able to keep running after a good cleaning of the process area-check the corona assemblies. Chances are you may need to restart the cyan.
        Any idea of the copy count on the current dev?
        • Metro Kari
          I don't have exact no. of clicks - but under 15,000.
          • charm5496
            • 2387
            This is usually due to your hopper not supplying toner to the developer.
            Are you a tech or end user? This could get involved on the troubleshooting side of things....
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Under 15k and all ready your getting E20's. What are you printing. If your not a tech I would suggest you have somebody who know's how to mess around with this unit. Developer shoud last about at least 40k, depending on what your printing.
              • Metro Kari
                Thanks everyone - got my copier tech coming tomorrow so I don't make it worse than it is. Appreciate the input!
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Let us know.
                  Good luck.
