canon IR 2200 error code E000002-0000
  • geltrons
    • Apr 2007
    • 37
    Good day All
    hope some of you know the above mentioned error (E000002-0000)
    please help
    Regards
  • panalkar
    • Jul 2005
    • 43
    It's related to Fixing Assy
    • geltrons
      • Apr 2007
      • 37
      Thank you very much for that.
      Could somebody elaborate on that.
      and how to reset
      Thanks and regards
      • CanonHPTech
        • Apr 2007
        • 235
        ok sir, like I have told others before- reset it and forget it, if it comes back, well, run like hell! On the Cont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy. Good luck sir. I post this help, with the anticipation that you will post results. Thank you.
        The glass maybe half full, but less is more...
        Printer + Fax + Copier = Jack Of Many Trades,
        but Master Of None
        Color Copier = Not A Color Printer
        InkJet MFP = Not A Fax Machine
        B/W Copier = Not A Press
        Finisher = Deal Closer (salesman, not accessory)
        Copier Tech = Admin's Stress Ball (Scapegoat)
        • geltrons
          • Apr 2007
          • 37
          Good day All
          Thank you very much for the briefing. I am unable to tell the results now b,couse i have not yet inspected the copier. It was a service call from one of the vessel and i will be boarding the vessel probably on 4th. Sure i will post the results.
          Thanks & regards
