CANON IR3100N ERROR E020-03a2
  • joetech
    • May 2010
    • 7
    [Error Code] CANON IR3100N ERROR E020-03a2
    The first time this code popped up, we replaced the cyan developer unit and initialized it according to the manual. It has popped up again now. Any suggestions appreciated. Thanks, joetech
  • tinnyjay
    • Oct 2009
    • 663
    Check ATR sensor for any break,or at least clean it.
    "Who loves the roses,must also bear thumbs"
    • teckat
      • 16083
      Firmware should be v49.02
      Inspect Drum Surface , if poor replace Drum
      trouble shooting can help you isolate the problem.
      1. If possible make 10 color copies to force the ATR sensor to take readings. Then compare the SGNL reading for the color that is generating the error and additional colors in Service Mode; COPIER>DISPLAY>DENS>SGNL-Y/C/M with the Initialization setting in COPIER>ADJUST>DENS>SGNL-Y/C/M.
      COPIER>DISPLAY>DENS>SGNL-Y/C/M arethe ATR Sensor readings of the Developer in its present condition and should be within +/- 100 of the Initialization settings.
      COPIER>ADJUST>DENS>SGNL-Y/C/M arethe Initialization settings that the copier maintains and are usually between 400 and 650
      2. If the Initialization setting is outside these numbers the Developer Unit will need to be replaced.
      When replacing the Developer Unit, make sure to execute:
      - COPIER>FUNCTION>INSTALL>STIR-Y/C/M
      - COPIER>FUNCTION>INSTALL>INIT-Y/C/M
      - COPIER>FUNCTION>INSTALL>SPLY-H-Y/C/M
      After Initializing the Developer Units print a P-print and keep with the copier.
      -COPIER>FUNCTION>MISC-P>P-PRINT
      3. If the ATR Sensor reading is over +/-100 of the Initialization setting; the ATR Sensor, Patch Image Read Sensor, Drum Unit and DC Controller are suspect.
      Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each color and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is close to or over 100% of its rated life.
      If the Drum Unit is not close to or over its rated life, replace the ATR Sensor and Patch Image Read Sensor. If the error continues replace the DC Controller.
      5. If over toning continues to occur the Toner Supply Clutch (CL7) may be sticking and need to be replaced.
      ATR Sensor Assembly PN: FM2-0096-000
      Patch Image Read Sensor PN: FH7-7629-020
      Developer Assembly (Black) PN: FM2-1751-000
      Developer Assembly (Yellow) PN: FM2-1752-000
      Developer Assembly (Magenta) PN: FM2-1753-000
      Developer Assembly (Cyan) PN: FM2-1754-000
      GPR-13 Drum Unit PN: 8644A004AB
      DC Controller PCB Assembly (IRC3100) PN: FG3-3846-030
      DC Controller PCB Assembly (IRC3170) PN: FG3-3847-000
      Toner Supply Clutch (CL7) PN: FH6-5005-020
      also update firmware
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1257
        I'm with Teckat---------check that firmware & update if necessary - full cleaning/PM -replace drum and check clutch.
        • ragajungle
          Thank you!
          Thank you!
          Thank you!
          This was a very thorough resolution. I have been fighting this very problem for some time on multiple turret mfd's. and YES these mfd's are wayyyyyy to needy. lol.
          • teckat
            • 16083
            see your problem areas/ copier at doctors office
