Fax utilities for IR 6020i
  • benjamin
    • Jan 2008
    • 13
    [Misc] Fax utilities for IR 6020i
    hi.. anyone can teach me how to use fax for IR 6020i? Is there any send function from the machine? do we need software and connect to pc?
    thx alot
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    (1) is there a fax board installed in the copier? Large bumpout cover on back of rear cover.
    (2) do you have the fax owners manual, if so, open it up and teach yourself how to use the feature...
    • charm5496
      • 2387
      thx alot
      The 6020 does not support the fax function. If you want to set up universal send you will have to configure the unit to email. I am sure if you do a search there are detailed instructions on how to do this on here already. If you need something of that nature I can PM it to you later.
      • mrfixit51
        • Oct 2008
        • 1975
        Hi Charm,, I stand corrected,, I could have sworn that the 20 series supported a fax kit,,, but I just skimmed the Service Guide, and see that you are correct sir!
        'Nuther senior moment...
        • benjamin
          • Jan 2008
          • 13
          thanks Mr. fixit51.. i can see when i press the * 2 8 * the fax function is display ready.. was the fax board already installed at my machine?
          • benjamin
            • Jan 2008
            • 13
            hi charm.. can u pleaseee PM me how to use email or universal send for my 6020i? thanksss
            • mrfixit51
              • Oct 2008
              • 1975
              You are the one that can see the copier, not I, so look on the back of the copier, upper rear cover, to see if there is a rectangular bumpout in that cover, with RJ11 ports on it...
              • SCREWTAPE
                East Coast Imaging
                • 3396
                There is no fax option for this model.
                So, I don't know what fax option he see's.
                • charm5496
                  • 2387
                  There is a "FAX" tab in service mode when you have U-SEND installed.
