canon ir c3200 "e000012-0002"
  • downhiller67
    • May 2010
    • 67
    good day!
    i have canon irc 3200, sometime when printing, there some data that jam, and error appears "e000012-0002", then im goin to turn off the machine, when turn on again, its okay, data that contains full color prone to jam, then the error appears. what wrong with the machine? could someone please help me.
    "paging sir teckat"
    thank you so much.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    The code refers to a drum ITB motor fault. Need to check if 24v is supplied to motor. I think that voltage can be interupted by a variety of microswitches that are in the same circuit. You will need to check those microswitches - especially MSW 5 & 6 or it may be necessary to trace power thru the circuit to resolve this issue but probably not because you can reset the fault.Check those switches! . Good luck----Blaze
    • teckat
      • 16083
      blazebusiness / on the money
      also check that all door interlocks are closed
      seems like 24v is lost during printing
      imageRUNNER C2620 / C3200 / C3220 .
      the interlocks are highlighted in red.
      • downhiller67
        • May 2010
        • 67
        good day!
        thank you for the replies. im going to work it out.
        hope i can find it.
        see yah!
        thank you and more power
        • teckat
          • 16083
          Originally posted by downhiller67
          good day!
          hope i can find it.
          see yah!
          INTERLOCKS are Door Switches
          Below is a diagram of the printer with the interlocks highlighted in red.
          • teckat
            • 16083
            Double click on pic above
            • teckat
              • 16083
              E012-0002
              Your ITB DRUM MOTOR M1 > Rotation and Drive voltage are interrupted during copying
              Loss of 24v/ and or poor door connections/ when u remove jams u are opening and closing doors/ look for a faulty connection/
              If u have a Sorter Connected/ make sure handle is locked into machine door latch when closed
