Anyone know how to change counter on iR5570 or iR4570, thank you.
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Canon , Inc.
It is illegal to tamper with this circuit in an attempt to falsify the counter readings of any Canon
Copier.
the Counter Memory, Serial Number and Main
Controller PCBs work as a set and are considered the “Soft Counter Circuit”. The Counter Memory PCB is
electronically stamped with the serial number from the Serial Number PCB. Neither the Counter Memory
PCB nor the Serial Number PCB can be swapped to other equipment.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
He said:
"Holding down "Zero" for 2 hours is very tedious.
So,go rest,because your very tired !!!"
"Who loves the roses,must also bear thumbs"Comment
mr patel
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
It is time to scrap out your copier then, and turn it into a parts machine. The people that are buying these copiers need to know that they are buying OLD copiers, not new ones. Replace all the consumable parts that need it and reset those counters."Once a King, always a King, but once a Knight is enough!"
