IR500 e00355-0001
  • hamdyyassin
    • 84
    IR500 e00355-0001
    i have a canon ir5000 mc old verision with error code e00355-0001 i change the main controller pcband the error still e355-0001 please i need help
    thanks
  • tinnyjay
    • Oct 2009
    • 663
    Check it here
    http://www.copytechnet.com/forums/ca...3300-e355.html
    "Who loves the roses,must also bear thumbs"
    • SCREWTAPE
      East Coast Imaging
      • 3396
      The E355 error code is due to no communication between the Main-Controller board and the Serial Number board,or the counter.
      Main controllers should not be swap. And if so, follow technical procedures.
      • teckat
        • 16083
        thanks
        You've Replaced or Swapped the Main-Controller board and now are getting an E355 error code on he imageRUNNER-iR LCD ??
        E355 error code is due to no communication between the Main-Controller board and the Serial Number board below it. The boards are connected by a 11 PIN yellow connector and cable. This yellow connector must be reseated on the new Main-Controller board when changed. The connector must be seated firmly on the board.
        You must go into Service Mode and clear the error code.
        1. Enter Service Mode: Press * Additional Functions, 2&8 simultaneously, then * Additional Functions again.
        2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
        3. Under the [FUNCTION] tab, select the [CLEAR] option.
        4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
        5. Reboot the machine.
        If the error occurs again:
        1. Make sure the connection is secure and tight to the Main-Controller board from the connector cable to the Serial Number board below.
        2. Re-seat the Main-Controller board into its slot.
        3. Go into service mode and clear the error code as explained above.
        * If the error still continues, you probably have a bad Serial Number board and it needs to be replaced.
