Nethawk USB-Parallel
  • Coling
    • May 2009
    • 13
    [Misc] Nethawk USB-Parallel
    Hi
    I have installed SST4.24 on Windows 7, but found that the inf folder required to install the Nethawk cable is not showing in the service support tool folder. I am using the new cable (FY9-4368). I have also tried the older tools. Has anyone had the same problem?
    Thanks in advance.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    I don't think it supports windows 7
    I know that FY9-4368 supports vista with Service Support Tool (SST) v4.22 or later.
    • Avalon
      RIkon Boy
      • Jun 2008
      • 53
      I run XP Pro and I had to install the Nethawk driver manually.I can mail it to you if you want to try it.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Its not supported for windows 7.
        Canon does not state it in any techpubs.
        I don't think device manager will detect it.
        • teckat
          • 16083
          Originally posted by Coling
          Hi
          Thanks in advance.
          Make sure u have the USB-Parallel Cable plugged into the computer, before install procedure.
          The INF folder is present in SST4.24>
          under_
          CANON\Service Support Tool\inf\USBPAdp
          The driver files for the USB-Parallel Cable are included with the Service Support Tool installation. They will be
          installed in the folder (for a default installation) “C:\Canon\ServiceSupportTool\inf\USBPAdp”.
          To install this driver so that the USB-Parallel Cable may be used, follow these directions (notice that the default driver
          selected by Windows will NOT be correct and will be over-ridden):
          ****Plug in the USB-Parallel Cable to the computer.
          Some balloons from the Task Bar will display showing that the computer recognizes the NetHawk USB-10 Cable and
          that USB Printing Support will be enabled.
          If this support had previously been enabled, the balloons will not display.
          Note:
          With Windows Vista, no specific driver is required since the OS built-in standard driver is used for the adaptor. This
          is applies to the USB-Parallel Cable (FY9-4368-000) only.
          Access the System Properties. This can be done by right-clicking on the My Computer icon or accessing the System
          Control Panel from Start Menu->Settings->Control Panel (Performance and Maintenance).
          Click on the Hardware Tab and then the “Device Manager” button.
          With the list of devices shown, select the “USB Printing Support” item under “Universal Serial Bus controllers”. With
          this item selected, select the Properties command from the Action menu.
          With the “USB Printing Support” properties window displayed, click on the Driver Tab. From here, click on the
          “Update Driver…” button to start the Hardware Update Wizard.
          When the Wizard starts, select the option “Install from a list or specific location” and click Next
          When this screen is shown, select “Don‟t search. I will choose the driver to install” and click Next.
          At this point, click on “Have Disk…”.
          This will bring up a dialog to select a location to search. Click “Browse…” to navigate to where the driver files were
          installed,
          “C:\Canon\ServiceSupportTool\inf\USBPAdp\”, and select the USBHWK.inf file. Click Open and then
          OK.
          the message about the driver not being digitally signed is normal. It is OK to
          install.
          Select the “NetHawk USB-10 Cable” driver and click Next.
          At this point, the driver files will be copied over to the System
          When the final screen is shown, click Finish.
          Note that the “USB Printing Support” item is now gone from the “Universal Serial Bus controllers” section of the
          Device Manager.
          Also note that a new “NetHawk Device” section has been created with a “NetHawk USB-10 Cable”
          item included.
          If the NetHawk section and item are not in the Device Manager, the USB-Parallel Cable will NOT
          function with the Canon utilities.
          • Coling
            • May 2009
            • 13
            Hi. Thanks for the input. I found that it is supported in Windows 7 without installing any additional drivers.
            Thank you.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Nice to know.
              Let us know how it'd worked out.
              • teckat
                • 16083
                Thank you.
                Canon always keeps techs in the dark, they should have updated that in latest SST 4.22 Manual, as I posted from it above ,it only states a note for Vista
                Thanks , Good Luck
                • Coling
                  • May 2009
                  • 13
                  Hi
                  It works 100% with Windows 7.
                  • teckat
                    • 16083
                    Hi
                    Us techs usually know more then Canon Support, it's all about trial & error, good work
                    • rickstapylton
                      Re: Nethawk USB-Parallel
                      Hey just thought i would add that the part number you guys are talking about doesnt come up anything anymore, new part number: FY9-4154-000
                      • teckat
                        • 16083
                        new cable is FY9-4368-000
                        USB-Parallel cable (FY9-4368-000) supports Windows Vista with Service Support Tool (SST) v4.22 or above.
                        USB-Parallel cable (FY9-4154-000)does not support Windows Vista regardless of the version of SST.
                        • its_just_a_copier
                          • May 2011
                          • 132
                          Has anyone had any success using an aftermarket USB-Parallel adapter with windows 7?
                          From what I'm hearing the FY9-4154-000 cable has recently become unavailable.
                          • teckat
                            • 16083
                            NO
                            • LALA
                              I need a picture Nethawk USB-Parallel cable (FY9-4368-000)
                              ex_lala@ymail.com
                              thank you
