IR1023if need to wipe out address book, etc.
  • panashiba
    • Jan 2007
    • 37
    We have one of these machines that was traded in and is now going back to a leasing company. We are not a Canon dealer but the customer has requested that we wipe everything out of the address book and/or copier. Can anyone tell me how to do this or how to access the service mode on this machine if that is where we need to go? Thanks in advance for any help.
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    These models don't have a HDD, but some have a USB memory stick. If it did have a USB memory stick it would be plugged into the main controller in the rear.
    Press additional functions(*), 2, 8, then additional functions(*) again.
    Scroll down until you see "Clear"
    Select "Tel & User Data" and press "OK"
    • panashiba
      • Jan 2007
      • 37
      Thank you. That worked perfect. I appreciate it.
      • CanonHPTech
        • Apr 2007
        • 235
        I would do a "Clear All" instead of "Tel & User Data" on it instead to start fresh. This will wipe any address book or network information and user settings. I was told that USB drive only held temporary scan image area for scan enabled machines? You can pull it out of machine and machine runs fine without it.
        The glass maybe half full, but less is more...
        Printer + Fax + Copier = Jack Of Many Trades,
        but Master Of None
        Color Copier = Not A Color Printer
        InkJet MFP = Not A Fax Machine
        B/W Copier = Not A Press
        Finisher = Deal Closer (salesman, not accessory)
        Copier Tech = Admin's Stress Ball (Scapegoat)
