Everything on this model should reset by opening and closing the front door. If you keep getting a duplex error you probubly have a prublem that will not simply reset. The guilds for the paper size cycle when it is reset. Be there is nothing blocking them. These units are bad about getting little peices of paper in front of senses.
Tell you what, I'll give you my phone number, you give me your credit card number, and I will tell you everything you need to know about the mythical Canon EP4000 copier.
The glass maybe half full, but less is more...
Printer + Fax + Copier = Jack Of Many Trades,
but Master Of None
Color Copier = Not A Color Printer
InkJet MFP = Not A Fax Machine
B/W Copier = Not A Press
Finisher = Deal Closer (salesman, not accessory)
Copier Tech = Admin's Stress Ball (Scapegoat)
