canon s6300 printer
  • Naveed Shahid
    • May 2008
    • 162
    canon s6300 printer
    hello every one
    i am faing a problem in canon printer s6300 i need to clear waste ink counter i am trying to enter in service mode but i cant can any one give me a information
    thanks
  • teckat
    • 16083
    Originally posted by Naveed Shahid
    hello every one
    thanks
    Service Mode Operations
    1. With the printer turned off, hold down the RESUME button and press the POWER button (the green indicator lights and the desired service function can be selected).
    2. While holding down POWER button, let go of the RESUME button and then press the RESUME button twice in succession. Then let go of the RESUME button and POWER. Troubleshooting button. (Each time you press the RESUME button, the indicator’s color toggles between orange and green.)
    3. During printer initialization, the green indicator blinks. When the green indicator stops blinking and remains on, press the RESUME button the stipulated number of times to execute the desired service function listed below. (Each time you press the RESUME button, the indicator’s color toggles between orange and green.)
    Press Indicator Function
    0 – times Lights green Power off (Even if there is no Print Head mounted, the carriage will return to the home position and lock.)
    1 – time Lights orange Service/factory test printout(Including ink sensor check)
    2 – times Lights green EEPROM information printout
    3 – times Lights orange EEPROM initialization (All the information will be reset to the default, but the printer settings will not be affected.)
    4 – times Lights green Clears the waste-ink counter (if you printer getting waste ink problems).
    5 – times Lights orange -Market area (printer) setting
    After the power is turned on and a service function is RESUME button the stipulated executed, press the number of times to set the market area setting. Lights green Press the POWER button to return to the service function
    6 – times or more selection mode.
    After selecting the service function, press the POWER button. The green indicator lights and the service function will be executed.
    (After the respective function is executed, the printer returns to the service function
    selection mode.)
    • Naveed Shahid
      • May 2008
      • 162
      Hello Sir ,
      Thanks for reply
      Orange/
      green
      7 toggle blinks when i on the printer
      The waste ink absorber has reached 100% of the
      waste ink capacity.
      <Suspect Part> Waste ink absorber, control board
      i see in service manual its problem in waste ink i clean already i try to clear by service mode but i cant can u give some good idea i 100% sure i cant clear the waste toner counter waiting ur reply
      thanks
      • teckat
        • 16083
        did u replace waste-ink absorber ?
        After replacing the control board or waste-ink absorber, reset the EEPROM and
        restore the printer settings. Then do a test printout to check the results
        After selecting the service function, did u press the POWER button
        The printer uses the total waste-ink absorption amount recorded by the EEPROM as
        the basis for determining whether the waste ink is full.
        Therefore, after replacing the waste-ink absorber, be sure to reset the total waste-ink
        absorption amount.
        Also, after replacing the control board, be sure to reset the new control board's
        EEPROM and to also replace the waste-ink absorber.
        • Naveed Shahid
          • May 2008
          • 162
          hello sir ,
          thanks for reply
          i clean the waste-ink absorber and i already clear the waste ink counter now printer is working fine thanks for ur support
          thanks
          naveed
          • teckat
            • 16083
            hello sir ,
            thanks for reply
            thanks
            naveed
